Old 05-02-2013, 02:25 PM
crtfour crtfour is offline
Boat: 1996 Prostar 205 LT1
Speedometer Question '96 205
I'm needing to replace one of the Airguide speedometers in my '96 Prostar 205. Since those speedo's seem to be hard to come by, what replacements would work with minimal modification? On Ebay, I regularly see ones removed from early 2000's Mastercrafts, but would those work? Thanks for the suggestions as I have never changed out a boat speedometer before.
Rob
Old 05-02-2013, 02:28 PM
Snipe's Avatar
Snipe Snipe is offline
Boat: 1998 ProStar 190
I have used FARIA's in another boat. Out with the old and in with the new. As long as you have (if I remember) a 3 1/4 hole. they are not adjustable though.
Also check these guys out...http://greatlakesskipper.com
Old 05-02-2013, 02:31 PM
Or just use your smart phone with the GPS speedo app - or even better yet put in a perfect pass.. ... I love spending other peoples money...
Old 05-02-2013, 02:39 PM
Snipe's Avatar
Me too Mike... But we're here to help. If we can.
Old 05-02-2013, 02:55 PM
Ha....I am considering perfect pass. If I found the correct diameter, do they all pretty much plug up the same?
Old 05-02-2013, 02:57 PM
With the last post I was referring to the speedometer, not the perfect pass.
Old 05-02-2013, 03:08 PM
ahh you already have one... then faria - or the GPS converted airguides from www.classicboatworks.com
http://www.classicboatwork.com/class...e/agr/agr.html
Old 05-02-2013, 03:13 PM
Table Rocker's Avatar
Are you sure the speedo is bad and it isn't a clogged pitot or leaky line?
'96 ProStar 205 SD LT-1
Old 05-02-2013, 11:25 PM
jakethebt's Avatar
jakethebt jakethebt is offline
Boat: '96 Prostar 205 LT-1
Maybe some one will have one to sell since many on here install PP and have a spare.
I would first check the line, ballast and pitot. The ballast are mounted on the gas tank. If you remove the rear seat you can see them.
If you are looking to trouble shoot, just swap the lines going to the back of the speedos on the dash. That will help you figure out if it is the tubes or the speedo.
I seem to recall a company that restores the old airguides too. Maybe someone knows of a website.
1996 Prostar 205 LT-1
Old 05-03-2013, 02:16 PM
87 TriStar 190 87 TriStar 190 is offline
If you have plugged lines, see the Slow Reacting Speedo thread for my solution. Pretty dramatic photos at the end. Might help. I'm also thinking of adding a GPS speedo.
