Old 05-03-2013, 10:31 PM
mgs96ps mgs96ps is offline
Boat: A
96 LT1 water pump leak at weep hole
Hello TeamTalk Members,
Can anyone lead me to a thread on the subject and/or offer advice about the task?
Thanks for your help.
mgs96ps
Old 05-03-2013, 10:37 PM
supreme112279 supreme112279 is offline
Boat: 1996 mastecraft maristar 225
pump will require replacement. you can get a new opne at the local autoparts store. I replaced mine a month ago
Old 05-03-2013, 10:48 PM
Boat: A
Any troubles? Cost?
Table Rocker's Avatar
Table Rocker Table Rocker is online now
The water pump for a '92 Corvette will be the same as the one on your boat. You can rebuild your pump, but it doesn't cost much more to get a pump at the part store.
http://www.mastercraft.com/teamtalk/...ad.php?t=47547
'96 ProStar 205 SD LT-1
Old 05-03-2013, 10:51 PM
very straight foward, 135 dollars. I had to replace the temp sending unit cause I couldnt get the old one out of the bad pump
Old 05-03-2013, 11:03 PM
Boat: A
You guys are awesome. Thank you!
To all others...please keep sending posts on the subject. Pictures would be awesome. These are the times I am so glad that I have a direct drive.
Old 05-03-2013, 11:10 PM
Here is a thread on LT-1 cooling:
http://www.mastercraft.com/teamtalk/...ad.php?t=31626
You might check and see if your head steam vents have been moved to the front. Also, does your boat have a heater? You can buy a water pump with a heater port on the front that will provide hotter water.
Old 05-03-2013, 11:23 PM
Boat: A
No heater on my boat. Not sure about steam vents.
Old 05-03-2013, 11:26 PM
'92 Corvette pump is what you need then.
Old 05-04-2013, 07:29 PM
ricford's Avatar
ricford ricford is offline
Boat: 1996 Prostar190
If you buy the automotive pump it will have an output and input for the heater. You will have to buy a short piece of heater hose and clamps to join the two together. That's what I did. It was a pretty straight forward job. No real problems to deal with. While you're in there you might as well replace the 165 degree thermostat as well. If you buy an automotive one you'll have to drill a bypass hole in it. I couldn't get the marine version in time, so that's what I did. You're probably better off to buy the marine version if you can get a hold of one. Also, if your boat is a 96 don't you need a 96 Corvette pump?
