Old 07-31-2017, 07:35 PM
Justin D.'s Avatar
Justin D. Justin D. is offline
Boat: 2012 X-15, Ilmor 5.7
Trans Slipping?
Over the weekend I was pulling a wakeboarder out of the water and for a brief moment the RPM's shot up from 4 to 5k and there was a bad vibration, only lasted half a second. To me it definitely felt like the trans slipped. I had full factory ballast and 10 adults in the boat, so obviously a pretty heavy load on the trans. I checked the fluid and it still looked full on the stick. Any thoughts?
Boat is a 2012 x-15 with the 5.7 Ilmor, around 500 hours on the clock.
Thanks
Old 07-31-2017, 08:16 PM
MC25's Avatar
MC25 MC25 is online now
Boat: 2016 X30, 85 S&S
Prop cavitation?
-Aric
LONE STAR MASTERBASH 2018
Details released eventually
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
1985 S&S- For Sale
Old 07-31-2017, 08:32 PM
1redTA's Avatar
1redTA 1redTA is offline
once or can you repeat it?
1981 MasterCraft
19' Skier 351W PowerSlot
Old 07-31-2017, 08:33 PM
Cumminscj Cumminscj is offline
Boat: 86 Magnum Skier
Is the trans fluid discolored or smell burnt at all? If there is no evidence of failure I would say you had the boat overweight. Looks like it's rated at about 2300lbs. Subtract 900 lbs of ballast and that leaves 1,400 lbs for people and gear. Running overweight and trying to pull someone up the prop probably cavitated.
2000 Maristar 210VRS-weekend ride
1996 205 with LT1 cracked block-winter project
Old 07-31-2017, 08:37 PM
MC25's Avatar
I've had boats 3-4k over the "capacity" plate and never experienced that.
-Aric
1985 S&S- For Sale
Old 07-31-2017, 08:42 PM
Direct drive I have had them cavitate, it never recovered on its own though. Of course trash is the lake can do the same thing until that plastic diaper shreds.
Old 07-31-2017, 10:12 PM
Justin D.'s Avatar
What exactly is prop cavitation?
Old 07-31-2017, 10:19 PM
https://www.iims.org.uk/introduction...er-cavitation/
negative pressure cause by environment around prop when it spins.. water boils around prop spins thru air.. look at your prop for irregular spots.
Old 07-31-2017, 10:55 PM
What about the transmission filter on these units. Will they cause fluid starvation if they are plugged?
Old 08-09-2017, 01:56 AM
MasterCraft Ranger's Avatar
MasterCraft Ranger MasterCraft Ranger is offline
Boat: '91 PS190, '05 X10 (sold) & '11 X25
Got it a lot on the X10, JD. Usually while tubing and trying to accelerate out of a corner.
