Old 07-28-2013, 10:46 AM
rgardjr1's Avatar
rgardjr1 rgardjr1 is offline
Where did you find that cap. I've been looking at options but nothing is all the good so far. I saw motive they had a couple adapters but they were all like $40 and I didn't see anything that looked like an exact match.
I think it might be this:
http://www.trailerpartsdepot.com/ite...=32286&eq=&Tp=
The motive piece worked great for me.
2006 Maristar 200 SS
Old 07-28-2013, 11:01 AM
carracer's Avatar
carracer carracer is offline
Boat: MasterCraft 2008 X30
Originally Posted by 2010Prostar197 View Post
What orifice adapter are you talking about?? I am finally ready to install the UFP retrofit. The flexible brake line which has 1/8 inch npt threads just screwed into the Reliable bypass valve. I noticed on the bypass valve that it was setup for a flare type of brake fitting. The UFP is the same way. I checked others at the dealer and it was the same setup. Question is does the regular 1/8 npt flexible line suppose to just screw into the flare nut female fitting on the bypass valve?
The flare nut female that was in the orginal bypass has a very small orifice for a reason, It is designed to control fluid pressure on and off the callipers. Some people who keep there boats on lifts and then travel a empty trailer experenced wheel hop when braking because the small orifice did not let the pressure relax quick enough, so increasing that orifice size allowed fluid pressure after braking to relax quicker thus stopping wheel hop...
Old 07-28-2013, 11:13 AM
bturner2's Avatar
bturner2 bturner2 is offline
So you bought the Motive adaptor for the Reliable master cylinder? Is for which one did you buy?
Old 07-28-2013, 11:29 AM
carracer's Avatar
This was my set up the MityVac power Bleeder with auto-fill ,super easy did not spill a drop
ATTACH]98459[/ATTACH]
Old 07-28-2013, 11:49 AM
wtrjock's Avatar
wtrjock wtrjock is offline
Boat: Mastercraft, X10, 2005, MCX
Send a message via MSN to wtrjock Send a message via Yahoo to wtrjock
http://www.waterskis.com/650679-p/ma...nder_cap_r.htm
2005 Canadian Blue Flake X10
Old 05-29-2014, 09:26 PM
Boat: 2006 X30
I made the swap on my trailer last year - just before they released the pre-fab outer member from UFP. Worked out great. A buddy asked me to make the swap on his trailer so I ordered the pre-fab one. The UPS man brought it today - the bolt/pin hole spacing seems a bit wide to me (pivot bolt and pin). Holes are larger than pin and bolt - looks like it could work, with some persuasion, but an incorrect fit for sure. It has "UFP 08" stamped on both the upper and lower plates. Has anyone else that has used this confirm that this is correct? I don't want to tear into things or paint it and find that it doesn't fit.
Old 06-07-2014, 09:13 AM
Boat: 2006 X30
Update, for anyone who cares: Turns out I received a 4" outer member with plates designed for the 5" outer member welded to it (larger holes with slightly wider o.c. spacing). I contacted UFP's Tennessee division directly - both Dennis and Bill were very helpful (although a bit baffled as to how that could have happened considering that the 4" and 5" are built on different jigs). They sent a new one right out and I had it on my doorstep in a week. This one has "UFP 07" stamped on the plates. It is now painted with Dupont MasterCraft matched paint and ready to make the swap. Hope to get it finished later today.
Old 06-07-2014, 12:15 PM
2010Prostar197's Avatar
2010Prostar197 2010Prostar197 is offline
Boat: 2010 Prostar 197
Question is how many made like that made it out the door??
Good to hear you got it solved!
Old 07-30-2014, 10:55 AM
BHT BHT is offline
Boat: 07 MC X1
I may have missed this but can you tell us the cost? Also do you know if they have a chrome one available?
Old 07-30-2014, 11:09 AM
Reliable to UFP Actuator Retrofit Now Available
I believe it was around 400 shipped for both the new tongue and inner member for dual discs. Somehow 169 for the new tongue rings a bell. (Been a year and a half since I did it). Both pieces are quite heavy when shipped together.
www.waymires.com
Plus dealers I'm sure.
Waymires should be able to give you a quote.
The shiny piece in the picture is the way it comes. Plated but not chromed. I inquired about chrome but was told I would have to have that done locally which was an arm and a leg price. Painting materials weren't exactly cheap either but I had the compressor and devilbiss guns
