  #71
Old 04-26-2013, 07:54 AM
Wouter's Avatar
Wouter Wouter is offline
Boat: Mastercraft Prostar 190, 1990, Indmar Ford 351w GT40P, Borg Warner 1/1 Velvet drive 71c 10-17-004, pp stargazer, Acme 13
The position in the previous picture is not right for my engine. Finished product should look like this. Compare with first picture before dis-assembly. Make sure this is right.
Old 04-26-2013, 07:59 AM
Wouter's Avatar
Next comes the oil strainer assembly 55.
Replace in same order as when you dis-assembled.
Old 04-26-2013, 08:05 AM
Wouter's Avatar
Almost done now. I hadn't completely removed the valve assembly 39 during dis-assembly, so I did this now, cleaned it and returned it to its location in the case.
Old 04-26-2013, 08:13 AM
Wouter's Avatar
Next I returned spring 36 and its retaining cap. You'll have to press the spring to be able to place snap ring 35.
Old 04-26-2013, 08:18 AM
Wouter's Avatar
Now let's remove, clean and replace the forward and reverse shift lever. Be careful not to lose the steel ball that sits on popper spring 46. Check the lever moves smoothly from forward to neutral to reverse.
Old 04-26-2013, 08:22 AM
Wouter's Avatar
On the other side we still need to place the safety neutral switch.
Final bolt for me was the main shaft nut (1-1/2" hex socket)
Old 04-26-2013, 08:24 AM
Wouter's Avatar
A bit of paint on the parts that were scratched to avoid future corrosion and your done.
Old 04-26-2013, 08:26 AM
Wouter's Avatar
And here's the finished product.
Old 04-26-2013, 08:41 AM
Wouter's Avatar
Where I live, I only found one mechanic who could do the job (apparently this transmission is also used on some fishing boats) but he wanted to charge me 1200 (1560 $) for it (which is price of new) so I decided to give it a go myself.
I had no experience with transmissions and (if it finally works out well when I put it back in my prostar) all together I would say this an average difficulty job. It does require a good press and some unusual (to me) tools like a 1-1/2" socket. The transmission itself is very heavy, making it a PITA to pull from the boat.
Hopefully, I didn't forget or skip anything and am sure the other users will correct me if I did anything wrong.
Hopefully this will be useful to the next person. Personally, I will think twice before changing atf fluid on a transmission that hasn't been serviced in a decade (although I must say I am happy I did it considering the amount of debris that was in there.)
On a last note: there was also a bunch of crap in the water line of the oil cooler so that's also nice to have removed.
Super special thanks to Kyle and Cantrepeat for their knowledgeable insight.
Old 04-26-2013, 08:50 AM
Wouter's Avatar
And the pressure test figures compliments of Cantrepeat.
