  #31
Old 04-26-2013, 05:12 AM
Wouter's Avatar
Wouter Wouter is offline
Boat: Mastercraft Prostar 190, 1990, Indmar Ford 351w GT40P, Borg Warner 1/1 Velvet drive 71c 10-17-004, pp stargazer, Acme 13
Clean all parts.
I started with the oil baffle 74.
then the bearing retainer 4 (remove oil seal 3 (you should have a new identical one in your kit / check before removal))
Note: the ebasic kit contains more parts than you actually need for this particular transmission.
Old 04-26-2013, 05:19 AM
Wouter's Avatar
clean coupling 2.
Wouter's Avatar
clean ring gear 69.
Old 04-26-2013, 05:21 AM
Wouter's Avatar
clean forward clutch cylinder 84.
Old 04-26-2013, 05:23 AM
Wouter's Avatar
clean clutch pressure plate 71.
Old 04-26-2013, 05:24 AM
Wouter's Avatar
clean clutch spring 79.
Old 04-26-2013, 05:27 AM
Wouter's Avatar
clean snap ring 78 if you are reusing the old one (if you got a complete snap ring set you can discard the old one)
Old 04-26-2013, 05:29 AM
Wouter's Avatar
clean clutch pressure plate 77.
Old 04-26-2013, 05:35 AM
Wouter's Avatar
clean reverse clutch pressure plate 92. It's best to always keep your parts in the same order they came out but if things got mixed up at some point you have pictures or the manual to remember the right sequence.
Old 04-26-2013, 05:37 AM
Wouter's Avatar
clean forward and reverse adapter 99.
