  #111
Old 09-27-2013, 04:44 AM
Wouter's Avatar
Wouter Wouter is offline
Boat: Mastercraft Prostar 190, 1990, Indmar Ford 351w GT40P, Borg Warner 1/1 Velvet drive 71c 10-17-004, pp stargazer, Acme 13
Hi Samy, it's been a while since I did the rebuild but I think snap ring 78 did sit tight in a grove when I rebuilt my transmission (page 5 of the rebuild thread.) In your case: you don't see the grove at all or does the snap ring not provide enough pressure? Did you replace the right number of clutch plates? If you put in more than came out (remember there might be more plates in your rebuild kit than necessary for your particular transmission) they might sit higher than the grove and therefore not allow to put in the snap ring? Am not really sure how critical 78 is since the clutch assembly is really held together by snap ring 89 after using the press. Personally; if the problem is just that snap ring 78 sits in the grove loosely, I would order a new one and replace it to be sure.
Old 09-27-2013, 08:28 AM
8sammy8 8sammy8 is offline
Boat: 1984 Ski nautique 2001
Thanks for the reply. I did put the same number of clutch plates back in but even with nothing in there the ring doesn't fit. I had ordered a new one and same problem. I can see the grove, when i put the ring in it easily pushes right back out. When I took everything apart all that stuff just fell out, I was thinking that might have been the reason it was slipping.
Old 10-10-2013, 08:31 AM
Slackwater Slackwater is offline
Boat: 1975 Deadrise workboat, Crusader with Velvet Drive 71C
I have a 71c that is leaking transmission fluid out of where the no 48 shift lever goes into the transmission. I am assuming this is caused by a defective no 40 o-ring. Does this sound like a correct assumption? If so I'd just like to confirm that I can replace this o-ring without disassembling the rest of the transmission. Making such the spring doesn't go flying into the bilge. I.E. By just removing no. 33 valve cover plate, shift lever, etc. and pulling the no. 39 valve out. Then replacing the o-ring and reassemble. From your thread it appears I can do this in the boat as I have excellent access.
Old 10-10-2013, 02:14 PM
JMann's Avatar
JMann JMann is online now
This is a great thread that has me thinking about buying an old transmission to rebuild for the experience. I found one a couple hours away it's Borg Warner Velvet Drive. 1:1 ratio from a late 80's american skier. Does anyone know if this would fit into my 91 prostar 190?
Old 10-10-2013, 02:37 PM
strad's Avatar
strad strad is offline
Velvet Drive 71c rebuild
Is your 91 a Powerslot? If it is, a 1:1 transmission will be shorter than the one in your boat. What does the trans tag say on your transmission?
Old 10-10-2013, 03:05 PM
JMann's Avatar
No, I have a 1:1 in there now, not a power slot. I'm checking that it came off a ford motor (probably did) if so I assume it will bolt right in if I ever need it. If I get it I will probably rebuild it and sell it or just sit on it until some needs it. Looking for a winter project.
Old 10-11-2013, 12:24 PM
TRBenj TRBenj is offline
Boat: 1990 Ski Nautique
All of the above is true... the entire shift body can be removed easily, o-ring replaced, etc.
Old 08-02-2014, 09:26 PM
TexasT's Avatar
TexasT TexasT is offline
Boat: sinker extrordinare
I joined just to say thanks for the great write up. I have been looking for a boat and this opens up the idea that I can get one cheap needing trans work. Thanks again!
Rich
I like to wrench
Old 01-04-2015, 08:00 PM
tristar89 tristar89 is offline
Boat: 1989 Mastercraft Tristar 190, 351
I am in the process of tightening everything back up from the rebuild, and when I go to tighten up the fwd/reverse plate to the transmission housing, I am unable to spin the input or output shaft? It also doesnt sit flush to the housing until I tighten the bolts down. Assuming this is normal from the previous comment of forward and reverse engagement being rough the first few times of engaging drive, but I'd really like to confirm.
Dont want to get it back in the boat with a new motor and have to take it back out in the spring.
Any feedback is greatly appreciated.
This thread was great - wouldn't have been able to get to where I'm at without it.
Old 02-09-2015, 07:20 AM
jfw432 jfw432 is offline
Boat: other
Good writeup. Thanks!
One question though. I may have missed it but is there any reason that you didn't replace the metal sealing rings?
