#101
I think I too had 11. 2 in the lower left and 3 in each of the other corners. Thank you so much for this thread, it got me through the entire build with no problems what so ever!
Sent from my iPhone using Tapatalk |
#102
No reason you can't switch IMO and from what I am ready on none manufacture sights as well as manufacture sites as long as you meet Dexron III requirements at a minimum...but I have not switched to full synth yet...
Thanks, just making sure, I didn't loose one.
2004 Red/White/Black something or other. ![]() Formally, 1994 RED Mastercraft 205, Chevy 5.7 TBI. |
#104
So I am in the process of rebuilding my 71c and getting some of these smaller snap rings off is a pita - I bought the "heavy duty" snap ring pliers and they aren't helping.....any tricks to get these things off? 87 is the trouble maker.
#105
To get 87 off: if you got pliers with multiple tips find the beefiest tips and put them on. You can run a file over the outside edges a few times to make a flat spot on the tips. The round shape of my plier tips made it more likely to pop off. Try starting by getting one side started. I found both ends would not move equally. So squeeze like crazy and try to tilt the ring so one end is sitting on the shaft out of its groove. Now get a shim under it so that end cannot drop back down. At this point it is just a matter of squeezing the pliers hard enough and working the ring around. A second set of hands may be the key here because it is not hard to make progress and loose it trying to work your way around to the other side. I hope this helps! Sent from my iPhone using Tapatalk Last edited by f925; 05-23-2013 at 10:25 PM. |
#106
Did you buy "snap ring" pliers or "lock ring" pliers? I tried working with these things with the former and they didnt do a darn thing. Picked up some "lock ring" pliers from pep boys and life was much better.
#107
Got em off with a couple of screwdrivers - I need to remember how much it helps to take a break when stuck on something frustrating like this...
Surprised that the rebuild kit didn't come with the springs, soaking parts and waiting for springs to arrive. Painting outside in the meantime. Thanks for all the help |
#108
My saftey switch on velvet drive from S&S 1981 giving issues, its the 1:1.51 gear, which part can I use to replace. Will ski dim have it. Also I saw briefly you cleaned the oil filter, is that easy to do when it is still in the boat?
Well done on such a well documented rebuild! |
#109
Stick with conventional Dex/Merc or Dex III. Avoid high mileage formulations and synthetic and your tranny will live a long life. If youre overheating your engine badly enough to damage the transmission, youve got other major issues to worry about. |
#110
Snap ring 78
Hello I'm reassembling my tranny and snap ring 78 isnt fitting int the grove. It pulls out very easly. Is this normal?
Thread Tools | |
Display Modes | |
