Old 04-25-2013, 10:33 AM
Wouter's Avatar
Wouter Wouter is offline
Boat: Mastercraft Prostar 190, 1990, Indmar Ford 351w GT40P, Borg Warner 1/1 Velvet drive 71c 10-17-004, pp stargazer, Acme 13
As mentioned in my other thread :
http://www.mastercraft.com/teamtalk/...ad.php?t=53645
After changing the ATF fuid of my velvet drive 71c (model 10-17-004) (which had probably never been changed) the transmission started slipping severely. I decided, it was time for a rebuild, so here goes the write-up:
Tools/fluids/parts you’ll need:
- Dexron III ATF oil (preferably mineral)
- WD40 / engine cleaner
- Rebuild kit (includes forward and reverse clutch plates, seals and gaskets) http://bpi.ebasicpower.com/p/ALT23901
- Complete snap ring set or at least front bearing snap ring:
http://bpi.ebasicpower.com/p/ALT23255
- Possibly a new damper plate:
http://bpi.ebasicpower.com/p/ALTDA-106A/
(All these parts are also available elsewhere (i.e. skidim.) I have no affiliation with ebasic.
- An arbor press (mainly to compress the clutch pack)
- Snap ring pliers
- Rubber mallet (came in very handy)
- The usual assortment of torque wrench(es), socket (hex but also at least one 3/8" 12 points socket), etc.
- One big (38mm) 1-1/2” hex socket
- A feeler gauge 0.018" to 0.055" (to set clutch clearance)
- Shop or service manuals:
http://www.mastercraft.com/teamtalk/...ad.php?t=32581
different manual attached to this post. look below transmission tag.
Important things to remember:
This thread does not cover reduction ratios.
Stage the parts in order as you are pulling them out to remember how they go back in.
If you can, take pictures as you go in case you forget how/when a particular part came out.
Make sure to note position of pump housing (this is particular to your engine’s rotation direction.)
Read service manual and thread completely before starting
File Type: pdf Borg-Warner-Velvet-Drive-71C-72C-Transmission-Owners-Manual_red.pdf (1.49 MB, 5359 views)
Old 04-25-2013, 10:46 AM
Wouter's Avatar
Bellow is a diagram of the velvet drive: I'll use the diagram part numbers for the rest of the thread:
Old 04-25-2013, 10:47 AM
Wouter's Avatar
remove transmission from boat and note position of pump housing.
Old 04-25-2013, 10:50 AM
Wouter's Avatar
remove pump housing 104
Old 04-25-2013, 10:55 AM
Wouter's Avatar
remove pump drive gear 101 (slides off)
remove woordruff key 65 from drive gear assembly 64
Old 04-25-2013, 11:00 AM
Wouter's Avatar
remove 99 (12 points (10mm) 3/8" socket necessary)
Old 04-25-2013, 11:02 AM
Wouter's Avatar
forward and reverse adapter (99) comes off
Note sealing ring 96 is sitting on adapter 99
Old 04-25-2013, 11:08 AM
Wouter's Avatar
remove reverse clutch pressure plate (92) (it's sitting on the adapter in picture), outer clutch plate (91) and reverse clutch assembly (90)
stage in order
Old 04-25-2013, 11:13 AM
Wouter's Avatar
You can pull the drive gear assembly at this point (just pull out by hand)
Old 04-25-2013, 11:18 AM
Wouter's Avatar
Remove snap ring 87 (this one is very thight and often gets warped with removal, that's why you might want to order it with the rest of the parts)
and snap ring 88 (use snap ring pliers)
