Old 04-21-2013, 06:42 PM
Lumbergh's Avatar
Lumbergh Lumbergh is offline
Boat: 1991 ProStar 190
Adhesive for Depth Finder
Getting ready to install my depth finder in hull.
Anyone have experiences on the best epoxy to use to glue the transducer to the hull?
Maybe some 3M 4000/4200? Others?
Also, any clever ideas on how to fish the wiring from the behind dash thru to the front of the engine compartment? Don't really want to buy a fish tape just for this job.
TIA.
Old 04-21-2013, 06:49 PM
John 3:16-18
Old 04-22-2013, 12:21 AM
Retoxtony's Avatar
Retoxtony Retoxtony is offline
Boat: 2007 Tige RZ2, previously 99 MC205
I used 4200 on my last depth finder and it worked fine for the last 2 summers, but i was always told what works best is to use one of those 2 part epoxies that you mix. Also supposed to use clear stuff so you can make sure there are no air bubbles trapped that will mess up the readings.
Old 04-22-2013, 10:53 AM
CCAnderson's Avatar
i used a cheaper two part epoxy. no force applied to the transducer so the cheap stuff works just fine.
Old 04-22-2013, 11:18 AM
Boat: 1997 ProStar 205
The key is to have no gaps/bubbles in it. That will cause errors in the read out. I have used the cheap 2 part epoxy that comes with the kit. No issues on the 2 I have installed.
Old 04-22-2013, 11:42 AM
Boat: 1987 ProStar 190
Lumbergh, can you please share what location worked best for you? I get crazy readings and have found the best place to be near the shaft on the port side. I am hesitant to epoxy mine in place until I know for sure it's a great spot. I have to run a few more tests at different speeds.
Old 04-22-2013, 02:14 PM
mwg's Avatar
mwg mwg is offline
Boat: 2001 Prostar 205V
Don't laugh but I used a wax ring from a toilet... kneed the wax to get the bubbles out and stick it on. I used it to determine the best location and left it. It's held for over a year now and hasn't moved form its original location.
Old 04-22-2013, 03:43 PM
CCAnderson's Avatar
on my 2001 PS209 I mounted the transducer on the starboard side of the drive shaft log where the hull is only a single layer thick. Very rarely do I get an erroneous reading.
I did have to use a fishtape to get the wires up the display.
