Old 04-20-2013, 12:49 PM
erervin erervin is offline
Boat: 2005 Mastercraft 197 TT
Help Needed: 197 MCX Fuel Pump
Well, not a great way to start the year. Hooked the fake-a-lake up to my 2005 197 with the MCX and turned it over, but it would not start. I had it started about a week ago very briefly. Here's what I've noticed. Last week when it fired, I could hear the fuel lines prime when the key was turned. Today, that is not happening. Could this be the fuel pump? Thoughts?
I was considering bringing this to my local marina to take a look at and thought I'd first reach out to you guys on here, especially those of you who have changed the fuel pump yourselves. After a brief search on here, I found several threads discussing this topic. The NAPA two pumps that I believe will work on my boat are AFP E2065 and the NFP P74118.
Are there any step by step instructions out there? Would rather spend the $90 for the part rather than the $480 from MC. Thanks!
2005 ProStar 197 Tournament Team
#8 of 100
Old 04-20-2013, 12:57 PM
starman205's Avatar
starman205 starman205 is offline
Boat: 2004 Prostar 197TT
Search for Fuel Pump 101
Search this thread for Fuel Pump 101, it gives step by step instructions on what to check for and how to change the pump yourself. Try the link below to get there. There is a fitting on the fuel rail that you can check to see if there is pressure in the line. i am looking for a picture of it and will post if I find it.
http://www.mastercraft.com/teamtalk/...ad.php?t=25783
NEW BOAT:2004 197TT
PREVIOUS BOAT:1993 Prostar 205
Old 04-20-2013, 01:05 PM
Great, thanks!
I thought I'd check the fuel relay before I buy the new pump. Do any of you know where it is located and what the part number is for it?
#8 of 100
Old 04-20-2013, 01:18 PM
03 35th Anniversary's Avatar
03 35th Anniversary 03 35th Anniversary is offline
Boat: Searching
Emergency Kill Switch....
Old 04-20-2013, 02:15 PM
Jerseydave's Avatar
TT Hero
Check the harness plug where it is attached to the top of the fuel pump module. Sometimes poor contacts will cause the pump not to run. You should also test for fuel pressure before installing a new pump.
I was njskier on here.
Old 04-20-2013, 03:53 PM
A $20 gauge from auto zone could save you a lot of work.
Tim
Old 04-20-2013, 05:51 PM
agua4fun's Avatar
agua4fun agua4fun is offline
Boat: Prostar 190 Sammy Duvall & 230VRS
x2 on checking the contacts on the electrical connector at the pump with a voltmeter.
Old 04-20-2013, 05:55 PM
Update. My gauges on the dash do not move or appear to be powered making me think I tripped a breaker or possibly the main circuit breaker. The toggle switches light up as to the devices attached to them (blower, acc1, acc2, bilge, etc). I checked the three main relays and everything looks good.
Headed back out to check the circuit breakers. I checked fuel and there was pressure at the rail. I also checked verified that there was no power to the pump. Ideas where to start?
#8 of 100
Old 04-20-2013, 05:56 PM
Boat: Searching
Emergency Kill Switch.....
Old 04-20-2013, 06:37 PM
Should have mentioned, emergency kill was the first thing I checked.
Well I went back out there and low and behold, gauges lit up. So I hooked it up to water again and she fired right up. It must have been a loose connection somewhere.
Thanks for your responses!
#8 of 100
