Old 04-19-2013, 06:53 AM
nautique nautique is offline
Boat: X2 MCX Loaded
ballast is empty himself while driving x2 / 08
Hi,
I have a X2 / 08 with extra ballast-fatsacs in front and rear, connect with the hardtanks.
All the tanks are empty himself while driving. What is the problem? Wat can i doe ?
Old 04-19-2013, 08:07 AM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 2005 x-10
Sounds to me like a valve that is stuck in the open position. I assume it is not draining out of the drain hole in the side of the boat.
Old 04-19-2013, 09:16 AM
snork snork is offline
Boat: 07 xstar
check for worn impellers
Old 04-19-2013, 09:24 AM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
Like snork said, check your impellers. If they aren't green, replace them with the green ones.
Old 04-19-2013, 02:52 PM
Boat: X2 MCX Loaded
Ok. I will check the impellers and let your know THX
Old 04-19-2013, 03:36 PM
JRW160's Avatar
Boat: 2003 X2
If they aren't dumping into your bilge, the only way they can be draining is out the bottom of the boat. The impellers are supposed to prevent that form happening. If they are worn out they could be letting the water out. Also, I think the yellow ones had problems with this and the upgrade to the green ones will fix it.
Old 05-12-2013, 08:45 AM
Boat: X2 MCX Loaded
There was the old yellow impeller in all pumps, i am install the green impeller and there works . No more problems. THX ALL
