Old 09-02-2013, 07:33 PM
Topp dawg Topp dawg is offline
Boat: 2003 Mastercraft X10
Blower help.
Today my blower would not work at all on my 2003 x10. I unplugged it and plugged it back in and that did not work. It is not tripping the breaker. I also have a check engine light on. Could the check engine be related to the blower not working?
Is there any other troubleshooting I can do to get the blower working, or should I just replace it?
Old 09-02-2013, 07:44 PM
Footin's Avatar
Footin Footin is offline
Boat: 2007 Maristar 200VRS X2
Use a test light to verify you have power the the blower first.
OH-IO!
Old 09-02-2013, 07:45 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
The blower will not cause the check engine light, First I would see if your getting voltage at the blower with it turned on with a multimeter that will tell you if it's burned up or if you have an electrical issue.
/spôrk/
Old 09-02-2013, 08:38 PM
If it is getting power then should i just replace the blower?
Old 09-02-2013, 09:08 PM
After confirming it has a good ground.
Old 09-03-2013, 11:55 AM
I went out to troubleshoot the blower today and before I could do anything I just wanted to check it one last time and it worked, like magic. I tried it 10 more times and it worked every time. No clue why it worked today or even why it stopped working the other day. My boat may have a ghost. Check engine light is still on though.
Old 09-03-2013, 12:09 PM
You may have a corroded connection, a switch getting ready to fail or your blower may be on it's last legs. Looking at the connections is the easy part. Good luck.
Old 09-03-2013, 02:24 PM
The connections on the battery do look corroded. Can I just use contact cleaner and a wire brush?
Old 09-03-2013, 02:33 PM
Yup. Stainless wire brush does an especially good job.
Old 09-03-2013, 03:58 PM
Thanks man
