Old 10-26-2007, 10:28 AM
captain planet's Avatar
captain planet captain planet is online now
Boat: 1998 Prostar 190 Anniversary, LT1
Unhappy More Suburban issues
I have a 2000 Suburban that is giving me starting issues. A little more than 2 weeks ago it started starting hard. Starter working fine, but didn't seem like it was getting enough gas because when it starts hard if you hit the gas a little it starts up and runs fine. When starting the lights REALLY were dimming. It was ready for a new battery before this winter anyway so I got a new battery. I have run into where the battery will have enough juice to turn over the car, but not enough to run the fuel pump at the same time, replace battery, fix problem. Well not in this case. I also put in a new fuel filter at the same time as the battery.
It still has the same problem and seems to be getting a little worse. To me it seems like this happens when the truck is already warm. Cold starts don't seem to have this problem, although my wife says it is all the time now. Anyone have this problem?
FOR SALE 1998 ProStar 190 30th Anniversary, Corvette LT-1,
RON PAUL FOR PRESIDENT
"Don't steal. The government hates competition." - Ron Paul
Old 10-26-2007, 11:10 AM
P-hat_in_Cincy's Avatar
P-hat_in_Cincy P-hat_in_Cincy is offline
Boat: MasterCraft Prostar 205V "wakeboard edition", 2004
I'm trying to jog my memory banks, but we had something similar. I think it ended up being an EGR wire harness. I can't recall if we had starting issues and/or stalling after driving (warm) at low RPM.
Did you have your fuel pump replaced? Was it under warranty?
2004 MasterCraft Prostar 205v 'Wakeboard Edition'
Old 10-26-2007, 11:20 AM
Yea, there was a wiring issue on the sending unit that was recalled so to repair it they had to replace the whole fuel pump/sending unit assembly. That was with approx 60K miles. There are now 85K on the truck.
Once the truck is running there is no issue. It is only when starting.
Old 10-26-2007, 12:05 PM
Jerseydave's Avatar
TT Hero
I also have a 2000 suburban, do you have a copy or info on the recall? My truck has not seen a dealer in over 4 years, maybe I should inform them of the recall so I can get my fuel pump replaced. I do have a fuel guage problem once in a great while, where it goes to E and then back up to normal again.
Have you checked for trouble codes on yours? A new battery should have plenty of power to crank the engine and run fuel pump too. Maybe a bad battery cable or connection to ground? Just guessing.
I was njskier on here.
Old 10-26-2007, 12:17 PM
That is one of the symptoms.
Hopefully this link will get you to the text of the recall. Read the last line of the 'consequences' for your listed item.
CP...see if you have codes. A improperly functioning EGR can cause issues with starting/running conditions. I think they are about $80 and very simple to change. However, like I said, one dealer diagnosed as EGR but another (correctly) diagnosed and fixed as an EGR wire harness.
Old 10-26-2007, 12:23 PM
I'm not getting any check engine messages. If the computer was getting some reading it didn't like, wouldn't it let me know about it via 'Check Engine'?
Old 10-26-2007, 12:48 PM
Make sure the indicator light lights up upon 'Key On'. If you are by an Auto Zone, or the likes, they typically will scan for free. At least you'd know.
Do a search in this forum and/or join and post.
Automotive Forums...YUKON.
Old 10-26-2007, 02:04 PM
bcampbe7 bcampbe7 is offline
Boat: Tubtime Tugboat
Send a message via MSN to bcampbe7
Is it like the starter is dragging?
My in-laws had a Suburban (pre-2002) and when warm the starter would drag. The dealer told them it was because the starter was too close to the header/exhaust and was getting too hot.
Could be your starter going bad...
If my words don't make sense, try reading them backwards.
Old 10-26-2007, 02:13 PM
Naw, the starter is strong. It sounds like P-hat may have the answer. Hey P-hat, was the wiring harness a pricey fix?
Old 10-26-2007, 02:18 PM
dog paw's Avatar
dog paw dog paw is offline
Boat: 1984 19 skier Powerslot
I have the campaign with the vin breakpoints I'll paste it. More than likely you would be getting notices out the wazoo if yours was involved. If its close to 100k better be thinking about replacing the pump anyway. The fuel gauge thing is caused by the wipers on the level sensor in the tank wearing off. Very common on a lot of GM vehic's
A couple other things that cause that problem are the fuel pressure reg on the ingectors failing and letting fuel bleed off into the intake while the engine is off. Another easy thing to check and clean is the throttle bore. They get "coaked" up with goo and it throws off the minimum air rate causeing hard starts without having to press on the accell Take the snorkle off and spray it down, open the throttle and wipe out the bore. We have seen that fix a few vehicles with that problem. (my luck is never that good though )
Bob
Oh, EGR's will not cause a hard start without other driveability issues....... Dont make your problems any worse!
Subject: Product Safety - Fuel Module Reservoir Assembly #05027A - (03/10/2006)
Models: 2000-2001 CHEVROLET 1500 SERIES SUBURBAN
2000-2001 GMC 1500 SERIES YUKON XL
THE SERVICE PROCEDURE IN THIS BULLETIN HAS BEEN REVISED TO INCLUDE THE USE OF TOOL J 41413-300, EVAP CAP/PLUG KIT. PLEASE REVIEW THE SERVICE PROCEDURE IMMEDIATELY. DISCARD ALL COPIES OF BULLETIN 05027 ISSUED OCTOBER 2005.
Condition
General Motors has decided that a defect, which relates to motor vehicle safety, exists in certain 2000-2001 Chevrolet 1500 Series Suburban and GMC 1500 Series Yukon XL vehicles. Some of these vehicles were built with fuel module reservoir assemblies that contain fuel pump wires and/or connectors that may overheat under certain operating conditions. Fuel pump wires that overheat may become exposed and result in one or more of the following conditions: 1) if the ignition circuit wire is exposed and shorts to ground, the fuel pump fuse will blow, disabling the fuel pump and causing an engine stall or no-start condition; 2) if the ignition circuit or ground wire is exposed and shorts to the fuel level sender card wires, inaccurate fuel level readings may result; 3) if sufficient heat is conducted to the pass-through connector, a hole in the connector may result, which may cause a Service Engine Soon light to be illuminated during the emission system diagnostics routine. Fuel vapor, and in some cases liquid fuel, may leak out of the fuel tank through the hole in the connector body. If a sufficient amount of fuel were to leak out and if an ignition source were present, a vehicle fire could occur.
Correction
Dealers are to remove the fuel tank, remove the fuel module reservoir assembly, and install a new service kit. The service kit includes a new pass-through connector, wiring harness for the fuel pump and fuel sender card.
Vehicles Involved
Involved are certain 2000-2001 Chevrolet 1500 Series Suburban and GMC 1500 Series Yukon XL vehicles built within these VIN breakpoints:
Year
Division
Model
From
Through
2000
Chevrolet
Suburban
YG100002
YG229688
YJ100001
YJ211728
2001
Chevrolet
Suburban
1G100015
1G289620
1J100003
1J318221
2000
GMC
Yukon XL
YG100003
YG229685
YJ100017
YJ211810
2001
GMC
Yukon XL
1G100013
1G289614
1J100013
1J318207
Important: Dealers should confirm vehicle eligibility through GMVIS (GM Vehicle Inquiry System) prior to beginning recall repairs. [Not all vehicles within the above breakpoints may be involved.]
For US and Canada
A running apology for misspells and general butchering of the Kings English
