Old 04-14-2013, 12:32 AM
kpickett's Avatar
kpickett kpickett is offline
Boat: 1994 Prostar 190 - LT1
LT1 coolant temp sensor
I'm changing out my water pump on my '94 LT1. I can't get the coolant temp sensor out of the old pump. I guess after 19 years, I could use a new sensor.
Discount Inboard Marine has the sensor, but I need it tomorrow. They have one at NAPA.
Does anyone know if the automotive is the same sensor? This is the one at NAPA. Same connector.
http://www.napaonline.com/Catalog/Ca...075_0342213770
Old 04-14-2013, 12:37 AM
Table Rocker's Avatar
That sensor will be fine, as will a water pump for a '92 Corvette. Have you already bought the pump?
'96 ProStar 205 SD LT-1
Old 04-14-2013, 09:14 AM
supreme112279 supreme112279 is offline
Boat: 1996 mastecraft maristar 225
go to any parts store, its the same sensor. I replaced mine last weekend. It was 16 dollars.
Old 04-14-2013, 11:10 AM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
An automotive pump will work but I believe the wp is marine specific for corrosion resistance w raw water so may not last as many years.
'06 X2 MCX
Old 04-14-2013, 11:13 AM
skidim told me to put an automotive pump on mine.
Old 04-14-2013, 12:16 PM
I rebuilt my original factory water pump with new bearings and seals. It was an aluminum body with a steel impeller just like the auto units. The impeller was rusty and pitted, but I cleaned it up and put it back in.
Old 04-14-2013, 12:49 PM
kpickett's Avatar
Thanks for the advice, guys. Yes, I bought a pump for a '92 Corvette. It's the same as the one I just took off.
Old 04-14-2013, 01:13 PM
Automotive, but still specific to the LT-1, right? If not, your heads will go away pretty soon. The LT-1 pump cools the heads first, then the rest of the engine.
Old 04-14-2013, 01:22 PM
Yes LT1 specific.
Old 04-14-2013, 01:24 PM
He would have to get a pulley, new belt, etc. to run the wrong water pump since the LT-1 is shaft driven. Hopefully it would be hard to make that mistake.
