Old 05-17-2013, 08:24 PM
Indyxc Indyxc is offline
Boat: 2006 Mastercraft X2
06+ X2 Impeller Change
Hello all,
I've changed many impellers, but my 06 X2 is asinine. (Just bought it).
The muffler box is right in back of the impeller housing, maybe 1 inch above it's center.
It looks like the muffler housing has to be removed, but before I do that, is there an easier way to do it?
I have a puller, but I can't get to it at an angle. Likewise, there is no evidence of the silencer housing ever being removed.
Thanks!
Old 05-17-2013, 08:37 PM
CantRepeat's Avatar
Boat: No Boat
Check this out.
http://www.mastercraft.com/teamtalk/...ad.php?t=54321
It can be done without removing the muffler.
Tim
Old 05-17-2013, 08:46 PM
I can't seem to get my muffler to move, even with all the clamps disconnected. I've pulled and pulled and pulled, and all I have accomplished is a massive fiberglass splinter.
I'd murder whoever designed this clearance.
Old 05-17-2013, 10:29 PM
Wow.
So after try to move the muffler around and it starting to make crunching noises, I just decided to pull the raw water pump.
For anyone that is interested, it is 3 allen screws bolts to the crankshaft, and then it comes out.
Once it's out, you replace the impeller, and put it back together.
As an engineer, I would like to get a hold of the guy at mastercraft designed for engine to boat integration, and strangle him.
Old 05-18-2013, 12:14 AM
sand2snow22's Avatar
Boat: Ri257
Mine is as tight as yours. With cover off, spray lubricant into housing. Bump engine over. lay down in port compartment. Grab lowest impeller fin with small vice grips. Shake while pulling. It will come out like butter. Just don't over tighten brass screw and snap it
Old 05-18-2013, 08:31 AM
bigmac bigmac is offline
MC Platinum
Boat: 2004 Maristar 230 VRS
Originally Posted by Indyxc View Post
Wow.
Classic boat engineering. Design it so it's easy to assemble at the factory, but without regard to accomplishing subsequent maintenance items. One would like to think that an expensive boat like MasterCraft would be designed smarter, but it ain't so.
'04 MariStar 230VRS/MCX
Old 05-18-2013, 08:52 AM
bturner2's Avatar
bturner2 bturner2 is offline
New cars are the same. Pretty much nature of the beast
Old 05-18-2013, 08:56 AM
Jerseydave's Avatar
TT Hero
^^this is exactly what I do, but I use angled needle nose pliers to pull the old impeller out.
Soak the old one with dish soap, and soak the new one also and it will slide right in.
I was njskier on here.
Old 05-18-2013, 09:00 AM
ttu's Avatar
ttu ttu is offline
ditto! except I just spray a little wd40 and bump the starter with the lanyard off. pulls right out.
Old 05-18-2013, 09:33 AM
CantRepeat's Avatar
Boat: No Boat
I would suggest changing to windex window cleaner. I think the seal in the back of the pump housing can be damage over time by petroleum based products. The windex is just as slippery as the wd. I also use the windex to install the new one.
Tim
