Old 04-11-2013, 09:02 AM
skiknox's Avatar
skiknox skiknox is offline
Boat: 1995 prostar 205
87 pure gas or higher octane 10% ethanol?
LT-1 motor what would be better to use
Old 04-11-2013, 09:08 AM
east tx skier's Avatar
Boat: 1998 Ski Nautique
I'd go higher octane and treat it for the ethanol. Your LT1 is set up for a higher octane and you will sacrifice a bit of performance going lower. The only noticeable problem I have had with ethanol in my boat is that it tends to gum up the antisiphon valve if I don't run the boat regularly and don't treat the fuel during the season. My hoses and other components don't seem worse for the wear. Plastic gas tank on my boat. So no worries there.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 04-11-2013, 09:46 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
Your LT-1 owners manual states minimum 89 octane, my corvette buddies say at least 91 octane rating for moderate to hard driving (like how our boats are driven) and 89 octane in an emergency, regardless of ethanol content, never run 87 octane and drive it hard or it will detonate to death. Of course other MC LT-1 owners might chime in with their experiences...
/spôrk/
Old 04-12-2013, 04:12 PM
JDJ_205's Avatar
JDJ_205 JDJ_205 is offline
Boat: Mastercraft Pro Star 205, 1995, 350 V8
Good Question.
I dont have an LT1 - just a regular 350 in my 95' 205. I've been using 87 octane the past few years.
East - what do you treat your fuel with during the season?
Held to a Higher Standard......Let's Face It Steak Costs More Than Hamburger - MASTERCRAFT
Old 04-12-2013, 04:20 PM
Originally Posted by JDJ_205 View Post
Good Question.
I have the same motor. I usually run premium because my can sit for weeks and fuel loses octane rating over time.
95 manual calls for minimum 89 octane - http://www.mastercraft.com/files/man...roSport205.pdf
Seafoam and/or Marine Stabil.
Old 04-12-2013, 04:42 PM
Not that I would recommend using low octane fuel, but doesn't the LT-1 have a knock sensor to retard the timing when experiencing detonation or pre-ignition to prevent damage? Of course the lack of performance with retarded timing wouldn't be any fun either. This coming from a Ford guy with a 1977 boat.
Old 04-12-2013, 05:02 PM
Rockman's Avatar
Rockman Rockman is offline
Yes, our 94 LT1 does have a knock sensor.
Not sure what gas the PO used (still about 1/4 of tank from PO last fall).
I am going to drain the tank and use for the lawn mower and fill up with 91 for the first tank and then switch to 89 going forward.
Only gas we use in our trucks (87 octane) or boats (89 octane) is Shell, BP and occassionally Speedway. Speedway, believe it or not does have good gas. We have never had any issues with them.
Old 04-12-2013, 05:06 PM
Spork's Avatar
Boat: Sporkcraft
The ecm is only able to retard the timing a couple of degrees, it will throw a mil beyond 5 degrees, continually using low octane with hard driving it will ping. Also fuel loses octane over time so add that to the equation.
Of course you already knew this
/spôrk/
Old 04-12-2013, 09:22 PM
supreme112279 supreme112279 is offline
Boat: 1996 mastecraft maristar 225
The lt1 being a high performance engine, it like higher octain gas. IT would problally run just fine on 87 but 89/90 would be better and 93 would be best. ethanol is ok if you use your MC often but I hate it. I personally run 93 non ethanol. on the knock sensor, Im not convinced it really works. My camero doesent run any different with it unpluged.
Old 04-13-2013, 11:29 PM
JDJ_205's Avatar
Thanks MikeG!
