Old 04-07-2013, 07:10 PM
Texas skier Texas skier is offline
Boat: Mastercraft Prostar 190 1991 351 ford
water pump hose
busted a water pump hose today going into the impeller. Should I be able to get a replacement hose at any marine dealer?
Old 04-07-2013, 09:36 PM
Yes...even NAPA should have them...
Old 04-08-2013, 12:38 AM
88 PS190 88 PS190 is offline
This a curved J tube or the intake hose.
One is molded other is generic.
Old 04-08-2013, 01:53 PM
Lumbergh's Avatar
Lumbergh Lumbergh is offline
Boat: 1991 ProStar 190
Skidim.com
Old 04-08-2013, 03:14 PM
bobx1 bobx1 is offline
Boat: Was 2007 X1 - now looking
Not sure of your year and engine model but if you have a 2007 RTP or MCX, read below:
RTP J-Hose Recall/Service Bulletin
A number of issues regarding the 81845010 J-hose that connects the water circulating pump to the thermostat housing on certain 2007 model RTP-1 and MCX engines have been reported. The hoses may have a weak spot resulting from uneven distribution of the reinforcement material when the hose was molded. The failures typically occur early in the life of the engine and result in the hose splitting and leaking water into the bilge of the boat. Although the failure of the hose causes major inconvenience to the boat owner, there have been no cases of engine damage or other permanent damage resulting from the failure.
From the point at which the issue was raised, all of the hoses have been tested and identified by a red paint dot on the front of the hose. Hoses on 2007 RTP-1 and MCX engines prior to engine serial numbers137187 should be inspected and replaced as necessary.
