Old 04-07-2013, 04:15 PM
Tristarboarder's Avatar
Boat: 2002 Xstar
'90 MasterCraft Trailer Prop Guard
Afternoon,
As part of my ongoing trailer rehab project, I decided to remove the steel supports that form the prop guard. They have been bent to h%ll ever since I purchased the boat/trailer. I assume that they SHOULD be straight. Just curious if they are supposed to be perfectly straight with the obvious 90 degree bends at the attach points. My plan is to take them to a local metal fab shop and have them heat them up and pound them back straight to the correct form. Any ideas on the original guard setup? Anyone have rear pics of the prop guard for either an early 90's Tristar or Prostar trailer? Thanks. Here are some pics of my mangled and bent steel...
Old 04-07-2013, 10:55 PM
d2jp's Avatar
d2jp d2jp is offline
Mine had a similar bend, but finding a shop to heat/bend them became a big challenge. Driving around town, I spotted a construction crew leaning on shovels (imagine that) and a back hoe parked next to them. For $15, they used the bucket to bend my prop guard back straight.
Jack
1992 ProSport 205
Smith Mountain Lake, VA
Old 04-07-2013, 11:05 PM
clrussell's Avatar
Mine is completely different than yours and is a 1990 prostar 190 on factory trailer. I would guess they should be straight with a 90 on the end up bolt up. Any metal shop should be able to do that 90, put in vise, heat with torch, bend to 90 let cool.
Here's a couple pics of mine Name:  ImageUploadedByTapatalk1365386690.214927.jpg
Tapatalk
Old 04-07-2013, 11:08 PM
ouch - what happened to the prop - what did you hit..
Old 04-07-2013, 11:11 PM
clrussell's Avatar
Don't know it's going to the prop shop before I get it in the water this year.. Bad thing is its a brand new oj 4 blade with about 10 hours on it
Tapatalk
Old 04-07-2013, 11:13 PM
Tapatalk
Ouch...
Old 04-08-2013, 12:12 AM
clrussell's Avatar
Yep... Gonna try to get it off next week and sent back to oj
Tapatalk
Old 04-08-2013, 02:02 AM
Boat: 2002 Xstar
Thank you for the pics and the info. I will follow up with progress..
Old 04-08-2013, 01:22 PM
Boat: 2002 Xstar
Does anyone else have the flat steel type guard setup like mine, as opposed to the square tube style? Looking for some pics of one that isn't all beat like mine...
Old 04-08-2013, 09:54 PM
Flat bar type prop guard
I have the same on my '88 Tristar trailer (built by SMP). The rear flat bar (with the tabs on each end) is supposed to be flat and level. The two longer bars are bolted to it and start out level and then angle up and bolt to the curved cross channel. A couple of pics attached that I shot from the port side as it is wedged into the garage. That side was bent when I bought it 15 years ago. On mine, the rear two bolts rub just a bit on the driveway and get ground down. I've replaced a couple times. After seeing how bent yours was, I was thinking mine was made from thicker material, but it is not. It is quarter-inch flat bars. Hope that is what your after.
