Old 04-13-2014, 03:37 PM
homer12's Avatar
homer12 homer12 is offline
Boat: MC Tristar 190 OB, 1989
Mgs96ps, looks like there is a key slot on it so probably a tapered fit like mine. Although I don't see a key sticking out like mine...is it in there?
Sent from my DROID RAZR using Tapatalk
Old 04-13-2014, 04:15 PM
mgs96ps mgs96ps is offline
Boat: A
Old 04-13-2014, 04:50 PM
I chickened out. I had high hopes of changing out shaft log hose and stuffing box packing...but I just did stuffing box with it on prop shaft and plan on keeping an eye on hose.
I bet yours would come off pretty easily. next winter or the one after I will be tackling the shaft hose as well as the cutlass bearings.
Old 04-15-2014, 12:42 AM
homer12's Avatar
I tried heat and PB blaster and under pressure with the puller tonight. No success yet. Will keep the PB blaster happening and puller on it hoping it just takes time.
Old 04-15-2014, 12:48 PM
Boat: A
Old 04-15-2014, 03:15 PM
homer12's Avatar
Just FYI - I have a 1" propshaft and the nut size on the end took a 1-1/4" socket.
Old 04-15-2014, 07:55 PM
TRBenj TRBenj is offline
Boat: 1990 Ski Nautique
Yikes, terrible advice being offered!!!
The shaft to coupler is an interference fit. Penetrating lubricants and anti sieze are useless. So are half-assed pullers. You need to press it off, or admit defeat and cut the shaft with a sawzall. Use some bolts or threaded rods and an appropriate sized socket against the output shaft of the transmission. It'll come. Heat will help, but wont be enough. Definitely use heat/ice on the reinstall though.
Old 04-16-2014, 03:51 PM
homer12's Avatar
TRBenj, you are right, I've done enough additional reading to read about interference fit. It is different from tapered in the sense it is a straight shaft to straight coupling (slightly undersized) right? I have no way of pressing it still in the boat unless you're referring to pressing it against the socket.
Do you recommend using the tranny shaft coupler to press the socket on the shaft or using something else? I only have this to use for 2-bolts at the moment. Maybe it's time to get some thick plated steel and make a piece to press 4-bolts against.
I've been applying heat as well as light taps to the coupling to get it to come off. Been using mapp gas.
Old 04-16-2014, 04:04 PM
Use the output coupler of the transmission to press the shaft out of the coupler. Use all 4 bolts and an appropriately sized socket. This is the tried and true method.
Or, if you know the shaft is bent, just cut it out with a sawzall and save yourself the hassle.
Old 04-16-2014, 04:15 PM
homer12's Avatar
I don't have any reason to suspect the shaft being bent. I think I'm going to take it to a machine shop though and have it checked and trued if they determine it needs it. So, no worries on bending or breaking the transmission output coupler? Just makes me nervous is all....
