Old 04-12-2014, 09:40 AM
homer12's Avatar
homer12 homer12 is offline
Boat: MC Tristar 190 OB, 1989
Got it started
So I got this started yesterday and having issues getting the coupler off the shaft (surprise, surprise ). At least 3 years ago the PO told me he had bent the shaft and had replaced it so this drivetrain have been taken apart before.
So far, I have put penetrating grease in it and tried with a 2-bolt puller to get it off. I have not wanted to use the transmission coupler as a press for fear of bending or breaking. Well, I've already broken a bolt with so much tension. What do you think for my next attempt - use heat and keep pulling or find from flat steel and make a 4-bolt plate to pull against? Here's some pics: You can see my homemade coupler wrench that worked pretty well. You can also see the bolt I snapped off.
Old 04-12-2014, 09:51 AM
Couple has some corrosion as you see. Probably some corrosion on the inside as well. I wouldn't try to force it off too much. Spray some more penetrating oil... keep the tension on it. I would heat it, use penetrating oil and tap at it while under tension.
Is the key still look lined up straight?
Will probably take a be a few days before it gives way.
Old 04-12-2014, 02:01 PM
homer12's Avatar
Thanks Mike! Key looks to be in good shape and lined up fine in key slot.
When using heat can you cause harm using too much? I've got a torch I can use. Also, will it pop off or just gradually start sliding off under tension? I put a small Sharpie line on the shaft to see if I was making any progress at all.
Sent from my DROID RAZR using Tapatalk
Old 04-12-2014, 02:07 PM
It will pop... had this trouble on a benz with wheels not coming off on rotation...
regarding heat... I would just heat the union of the coupler and shaft... some one else here had the same trouble - took a few days but it popped off... heating the union should help penetrating oil to get deeper...
Heat and tapping the coupler when under tension should break it loose - I am always amazed how a little corrosion will lock something up when there are tight tolerances.
Darn can't find the thread.
Old 04-12-2014, 11:06 PM
homer12's Avatar
Man, the more research I do leads me to more questions. Do most people heat the couplers in the oven to expand them to refit/reinstall them or just crank down on the nut real tight? Also, is it recommended to use some anti-sieze on the mating surface for future removal? thanks a ton for the help so far Mike.
Old 04-13-2014, 07:44 AM
19_Skier's Avatar
19_Skier 19_Skier is offline
Boat: 2001 19Skier
Looks like we were both dealing with the same issue yesterday! Thanks for the tip in my thread, if I have any success today will let you know, good luck.
Old 04-13-2014, 07:52 AM
mgs96ps mgs96ps is offline
Boat: A
Old 04-13-2014, 08:00 AM
Boat: A
Old 04-13-2014, 08:29 AM
Your on the right track here's a thread I found somewhere else.
http://www.pbase.com/mainecruising/pss_shaft_seal
Old 04-13-2014, 01:40 PM
TOO-TALL's Avatar
TOO-TALL TOO-TALL is offline
Boat: Mastercraft X2 2003 mcx
Good read
---Animal house
