Old 04-01-2013, 11:06 AM
The Youngster The Youngster is offline
Boat: 2003 Prostar 209
What Oil for Oil Bath Bearings???
I have an '03 MC trailer and want to make sure I purchased the correct oil for replacement in the oil bath (80W-90 gear lube). Also, any pointers on removing the old oil and replacing would be great as well.
Thanks - Clayton
Old 04-01-2013, 11:54 AM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
I think I used 75W-90 when I replaced mine. That 80W-90 should be fine. On my 2003 trailer, there was one screw on the hub. I removed it then turned the assembly so the opening left by the screw was facing down and drained it. It takes a long time to drain.
Refill it kinda slow because it takes a little time for the oil to make it to the front where the viewglass is. I refilled mine to the same level they were at previously. Probably about 3/4 full.
Old 04-01-2013, 12:47 PM
g-Dog's Avatar
g-Dog g-Dog is offline
Boat: 2002 Mastercraft Prostar 205V
I'm not sure if your hubs are different than the GOLD Hubs on my 2002 205V trailer...but mine recommends to "Add oil until all of the air is forced out and no air bubbles can be seen. Hub cavity is completely filled with oil (50wt). There is no void, which would allow water entry during submersion of trailer in water and cooling of oil."
File Type: pdf Trailer Buddy GOLD Axle Maintenance.pdf (193.8 KB, 2036 views)
Old 04-01-2013, 01:10 PM
JRW160's Avatar
Boat: 2003 X2
2002 used UFP hubs. They are supposed to be full. 2003 should have reliable hubs. I think the consensus on there is they should be 1/2 to 3/4 full. This thread has some info.
http://www.mastercraft.com/teamtalk/...ad.php?t=22711
Old 04-03-2013, 04:46 PM
You can unscrew the outer cap or the allen plug on the hub to drain.
If you have reliable oil bath hubs.
Bearing Lubrication – Oil
Below is a listing of approved lubrication
for all Reliable hubs and drums using oil
for lubrication:
(Only to be used when unit is equipped
with the Oil Bath Lubrication System)
Lubrication Specifications
Oil
Approved Sources
Valvoline Gear Oil 80W-90
SAE 90 Hypoid Gear Oil
Exxon Gear Oil 80W-90
http://www.reliablepmw.com/downloads...ear_manual.pdf
There was also a change in the reliable documentation to fill the hubs completely full.
Tim
Old 04-03-2013, 09:52 PM
GoneBoatN's Avatar
Boat: 2010 X-15 w/MCX - Sold!
...There was also a change in the reliable documentation to fill the hubs completely full.
Do you have a reference to where they changed that? All the documentation from Reliable that I've seen including the one you posted says to the top of the reliable logo which is about 1/3 to 3/4 full.
Old 04-04-2013, 03:20 PM
It's been a while, like 2 years since I read it but I'll look around. I found it when I was replacing my broken plastic caps with the metal caps. It might have been an MC tech bulletin(just look and it's not an MC TB). I think it had to do with condensation or water build up in them while half full.
I'm going on 2 years without issue with them full of 90wt.
Tim
Old 04-05-2013, 12:39 PM
jigster's Avatar
jigster jigster is offline
Boat: mastercraft x-10
Mine are full. No problems. Change annually with lucas oil bath bearing oil (has a semi picture on it) available at my local napa. As stated above, drain and fill process is slow if all you have is the allen screw like mine.
-jason
Old 04-05-2013, 02:19 PM
93Prostar190's Avatar
Our 2008 (different year than OP) manual states 50w oil .....
2008 Prostar 214 MCX
"Do you have Flake on that boat?"
Old 04-05-2013, 02:28 PM
My 06 MC trailer manual doesn't have anything on hub oil. All it has is stuff like bolt pattern and other safety checks.
Tim
