Old 03-30-2013, 01:06 PM
Originally Posted by Snipe View Post
Do you perhaps know the part number or are there different applications?
GF626 should work- IIRC, it's rated for 5 micron. At the tank, you can use a 10 micron filter. You don't want to use a very fine filter at the low pressure end (the tank, where the fuel is drawn from because gas' viscosity is such that shear occurs. A good visual for this is a kitchen faucet- the screen in the faucet causes shear, which is how it aerates the water. It's a major case of vapor lock at low temperature and at high temperature, it's even worse.
Old 03-30-2013, 01:47 PM
Table Rocker's Avatar
My '96 uses a WIX 33481 screw on filter after the fuel pump and a WIX 33003 in-line with clamps on top of the tank.
WIX 51061 is the long oil filter (I thought I would add that while I was looking at my filter numbers).
'96 ProStar 205 SD LT-1
Old 03-30-2013, 02:40 PM
Snipe's Avatar
Snipe Snipe is offline
Boat: 1998 ProStar 190
Thanks all. I think this should not have to be marine specific and can pick this up at a local NAPA dealer? BTW this goes on a '98 5.7 Vortec
Old 03-30-2013, 03:58 PM
WIX 33481 is NAPA Gold 3481
WIX 33003 is NAPA Gold 3003
Old 03-30-2013, 07:41 PM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 2005 x-10
I got a Puralator F21111 for the tank and F33144 for the engine and yes I got them at Autozone. Unfortunately, I did not have time to replace them and run the boat, bc I had to get back to town, so I guess it will have to wait until next time. I will take apart the fuel pump and check that screen as well. I kind of wish I had run the boat with the old plugs before I changed everything just to see if they could have been the issue, but I would think that new plugs should run just fine.
Old 03-30-2013, 07:53 PM
sethro's Avatar
sethro sethro is offline
Boat: 1998 Malibu Echelon and 1985 Stars and Stripes
I read your post, and what struck me as a possibility is that you said you set PP to 20mph. Did you disengage PP before trying WOT? That would be an easy fix and would mimic a fuel problem as PP tries to hold your speed back.
Old 03-30-2013, 08:01 PM
CC2MC's Avatar
Boat: 2005 x-10
Valid question, but yes I did disengage PP before WOT. I wish it were that easy.
Old 03-30-2013, 08:04 PM
SP Maristar's Avatar
Originally Posted by SP Maristar View Post
Our LT1 has two in line filters. One hereAttachment 91997and one here. Attachment 91998
The two filters shown here are NAPA 23481.
Old 03-30-2013, 09:02 PM
Try getting ahold of STX221... he had some LT-1 issues... and was able to solve them for cheap.
Old 04-20-2013, 11:11 PM
CC2MC's Avatar
Boat: 2005 x-10
I exchanged one of the fuel filters tonight just after the fuel pump. I want to check the screen on the fuel pump, but wanted to know where to access the screen to see if I need to clean it. I also need to know if the system needs to be primed before starting after cleaning the fuel pump. Do I need to do anything past turning the key to let the pump come on a couple times? Thanks for the help.
