Old 04-02-2013, 08:48 PM
turbozinke turbozinke is offline
Boat: 2005 Mastercraft X-Star
Gauges not working
I've got a 2000 Mastercraft 205V. It runs like a dream, but I'm some of my gauges don't work (Engine temp, oil pressure, and fuel) I've pulled the dash and i'm trying to figure out if its the gauges themselves or the wiring.
The engine temp for example has 4 wires going to it.
red with white stripe (i think it's positive)
Black with yellow stripe (I think it's ground)
yellow ( my guess is the voltage from the temp sensor)
blue (think it's the 12v for the light in the gauge)
Does anyone know what the voltage range the wire from the temp sensor should have for the gauge to work properly? Or for the oil pressure, or fuel?
Old 04-02-2013, 08:49 PM
88 PS190 88 PS190 is offline
Don't know that boat. Does it have breakers on the dash and are any tripped?
Commonalities would seem to be power?
Old 04-02-2013, 10:57 PM
I should also mention that none of these gauges move at all when I turn the key on
Old 04-02-2013, 11:30 PM
Flatwaterfooter Flatwaterfooter is offline
Boat: 2006 PS 197
Dep module
Old 04-02-2013, 11:36 PM
Manual for your boat is available here
http://www.mastercraft.com/files/man...s%20Manual.pdf
Breakers -says they are under dash - push each one in.
Fuse - might be one by battery - replace it.
Report back after -
Having several gauges each with different sending units (fuel tank/temp/pressure are all different switches) makes it highly unlikely it is anything other than a breaker/fuse.
Old 04-02-2013, 11:52 PM
Ok more info. I put a new MDC in last year because it had water in it from the year before.
I pressed all the fuses below the dash and none seemed to be tripped
I was wrong, the Fuel gauge does move. It goes from 0 to max as soon as the key is turned on
Oil pressure just flickers a little bit and does not move
Temp flickers a little bit and does not move
Voltage seems to work properly. It comes up to a little less than 13 when the key is turned on.
I moved the gauges around and plugged them into different spots and they all performed the exact same way no matter where I plugged them in. Now I'm thinking it might be the gauges????
Old 04-02-2013, 11:56 PM
MC25's Avatar
MC25 MC25 is offline
Boat: 2016 X30, 85 S&S
where are you at in the south? trying to see if anyone has stumbled on my old 205V.
-Aric
LONE STAR MASTERBASH 2018
Details released 12/17!!!!
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
1985 S&S- For Sale
Old 04-03-2013, 12:17 AM
drschemel's Avatar
Boat: 1990 Tristar 190 Sport
Does the light work? If none of them work, it sounds like a bad ground wire. Try running a jumper wire from the engine block to one of the ground posts on a gauge and see if it comes to life.
Old 04-03-2013, 12:19 AM
drschemel's Avatar
I guess it's probably not worth fixing. You better just trade me for my tristar. Everything works on it! Lol
Old 04-03-2013, 09:14 AM
I'm in Fort Smith, AR. The boat had an Indiana title.
The backlights in them do work, but its not a series ground like the gauges that have the posts on them
