Old 03-19-2013, 01:48 PM
Rockman's Avatar
Rockman Rockman is offline
Depth Finder Question
I read thru the many depth finder threads but could not get an answer to my question...how does the a depth guage that has a water temp sensor read the actual water temp? In order to read the water temp, a transom mounted puck / sensor would be needed correct?
We have a hummingbird on the BF200 and the puck just sits in the bilge near the rear of the boat. We do not have an air sensor or water temp sensor on the Hummingbird...just the depth sensor.
So on the 190, I would like to get a Lowrance that has all three options...air, water and depth sensors. Can anyone shoot me a link to one on Amazon for example that would contain all three options? Is there such a model with a thru-hull puck? My guess is no...
Thanks Doug for the PM about the Faria model you have!
Old 03-19-2013, 01:52 PM
^faria has a "thru hull" that will work with several models but don't think they sell it as a package. The transom units will pick up water temp but I can't stand them.
Old 03-19-2013, 01:55 PM
Rockman's Avatar
As much as I would like the water temp one, I would rather just have the depth guage and locate the puck placement right next to the shaft on the flat spot like others have done.
Old 03-19-2013, 02:26 PM
Ski-me's Avatar
Ski-me Ski-me is offline
Do you just want a Lowrance or will another brand work? Thru hull or just epoxied in the bilge area? I did the epoxy method and then put the water temp sensor in place of one of the speedo pickups.
http://www.boatersland.com/far-13852.html
- Jeff
1994 205, LT1
Old 03-19-2013, 02:47 PM
east tx skier's Avatar
Boat: 1998 Ski Nautique
Check your PM. I sent you a link to mine yesterday. The water temp sensor is very discreetly placed on the transom, below the waterline with the wiring run through the hole where the speedo tubing comes out (or came out). Pretty handy feature, especially this past weekend when we were wondering how cold the water was (beats jumping in to find out).
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 03-19-2013, 03:04 PM
Table Rocker's Avatar
Table Rocker Table Rocker is online now
Others have installed the water temp unit in a fitting on the raw water hose before the trans cooler.
I believe it takes some modification of the temp pickup unit.
'96 ProStar 205 SD LT-1
Old 03-19-2013, 03:37 PM
Rockman's Avatar
Jeff, I would prefer to just epoxy the depth finder in the bilge area...I will look at the Faria as you and Doug have mentioned. I need to replace both speedo pickups so I will just to the depth guage install at the same time.
Old 03-19-2013, 05:10 PM
Barefooter92's Avatar
I glued the ppuck to the floor and installed the temp sensor in the raw water intake by installing a tee in the line.
Old 03-19-2013, 06:13 PM
Lumbergh's Avatar
Lumbergh Lumbergh is offline
Boat: 1991 ProStar 190
That is pretty clever!
I bought a H650 to put in prior to the summer season, just have not got around to installing it. Just going to epoxy the sensor in the bilge.
This video is humorous and informative should anyone be interested in the project. The poster is quite a character IMHO (not me!):
http://www.youtube.com/watch?v=Jm07PMOwU9E
Old 08-28-2013, 01:22 PM
Bert's Avatar
Bert Bert is offline
Boat: Prostar 190 and X2
Then he sunk it
http://www.youtube.com/watch?v=dXJINL7AFWg
