Old 03-18-2013, 08:37 AM
nautique nautique is offline
Boat: X2 MCX Loaded
Smile X2 wiring diagram
Hi, i looking for a wiring diagram for the ballastsystem (switches, timerbox)i want install relays for ballastpumps. For X2 08. Thanks
Old 03-18-2013, 10:53 AM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
I have some for a 06. No timers though. Will try to find them and post them up.
'06 X2 MCX
Old 03-18-2013, 03:19 PM
Boat: No Boat
You have a couple of choices here.
1. Get your timers reprogrammed to just be on off type with a preset amount of time. There is a user here that reprograms them.
2. Rewire them with 3 relays to each pump. A couple of user here have done that.
3. Rewire them like the 06 none timer Mastercraft factory way which only requires 2 relays per pump. If you want to look at what is needed for this method check out the linked thread.
http://www.mastercraft.com/teamtalk/...ad.php?t=40934
It has the complete ballast relay wiring setup to include part numbers.
Tim
Old 03-18-2013, 08:53 PM
Boat: X2 MCX Loaded
Thanks a lot !!! Wow very good working - awesome. I want to try #3 with 2 relays.
Short question: the lights(LED) turn on when switch is on (fill+empty)? have the switch nummers for wire-cable connection?
Old 03-18-2013, 09:22 PM
Boat: No Boat
Yes the lights work on the switch. I would investigate what switches you currently have, they may work.
I'm sorry. I'm not sure what you are asking.
Tim
Old 03-19-2013, 06:41 AM
Stefan's Avatar
Stefan Stefan is offline
Think he means the pin numbers ("nummern" in german) on the switches.
If You Find Too Many Capitals You Can Keep Them...I'm German
Old 03-19-2013, 07:26 AM
Boat: X2 MCX Loaded
Sorry, yes i mean the pin numbers on the switches. I have the original switches there comes with the boat ( X2 08) original ballast KGB and 2 tanks in the rear. + add 3 fat sacs in.
Old 03-19-2013, 07:44 AM
Boat: X2 MCX Loaded
Old 03-19-2013, 09:24 AM
Boat: No Boat
Thank you for the help, Stefan.
I'll check to see if the poles(pins) on my 06 switch is labelled(numbered) but I don't think they were. Likewise, you will need to check to see if your 08 switches have 8 poles(pins) on them. They may be the exact same switch.
Tim
Old 03-19-2013, 06:52 PM
tr6coug's Avatar
tr6coug tr6coug is offline
Boat: Mastercraft 2007 X2 MCX
I can reprogram the timers for you. That way you don't have to build your own solution.
here is a thread about it.
http://www.mastercraft.com/teamtalk/...ad.php?t=50038
PM me if your interested.
'07 Navy Blue X2 MCX
http://www.wakeblaster.com/
