Old 03-18-2013, 09:51 AM
drschemel's Avatar
Boat: 1990 Tristar 190 Sport
tristar resurrection
Here's a teaser. Hull has been buffed, new decals applied, new carpet. Now waiting for upholstry to return from Viper before the beast returns to life!
Old 03-18-2013, 09:57 AM
Is the tennis ball there to protect the freshly polished surface, or does it reside there all the time?
Old 03-18-2013, 10:16 AM
Tristarboarder's Avatar
Boat: 2002 Xstar
Oh I feel teased....more pics please, I am partial to those Tristars
Can't wait to see it done, carpet looks great!
Old 03-18-2013, 10:32 AM
StudLEE's Avatar
StudLEE StudLEE is offline
Boat: Mastercraft Tristar 190
Definitely interested in the finished product! Can't wait to see more pics! I'm curious as to what route you went with the interior, a 'new school' design, or kept it original.. I'm also curious as to if you did anything different to those ugly, cheap cup holders we have!?.
Old 03-18-2013, 11:33 AM
drschemel's Avatar
tennis ball just there to protect cover until motor box returns. Although I kinda like it, might just keep it up there!
Old 03-18-2013, 12:20 PM
I had to ask.....you know how it is.
Old 03-18-2013, 12:34 PM
Boat shrank?
Just finishing up a carpet install as well on my Tristar. Having an issue getting the removable center panels back into their openings. Wondering if you had any similar issues? The new carpet is wrapped around the edges and glued to the bottom side and the openings have the carpet turned down one inch into the opening. Same way the original carpet came out. I used Corinthian carpet, 22 oz. (slightly heavier than original?) so I figured it would be snug. But the forward panel I had to force into the opening and it still is not down flush all the way and it is bowed in the middle due to forcing into the opening using a hammer and wood block. Dang that thing is tight.
If you did the carpet yourself, what weight carpet did you use? I thought I read all of the carpet/rehab posts but didn't see that issue come up before. Like the dark gray you used though. I went with a gray patterned carpet in lieu of the original dark navy blue that came out.
Old 03-18-2013, 03:37 PM
drschemel's Avatar
[quote=
If you did the carpet yourself, what weight carpet did you use? I thought I read all of the carpet/rehab posts but didn't see that issue come up before. Like the dark gray you used though. I went with a gray patterned carpet in lieu of the original dark navy blue that came out.[/QUOTE]
Wish I could help you but a local boat shop was needing some business so I let them do it. The carpet was a heavy grade - came from a local bass boat manufacturer (Bass Cat) and he did get it onto the seams somehow. We only actually removed the middle panel behind the motor. With the closed bow, the front panels are nearly impossible to get out! Pretty obvious that MasterCraft put the carpet in before they put the top of the boat on. Dark grey was original on my boat, we matched the carpet that is in the bow storage.
Old 03-18-2013, 05:47 PM
Okay, thanks for the reply. Might have been a good decision to let someone else do it. It has been time consuming, although not too difficult. And I've read where the forward floor panels are difficult to remove on the walk-through models. On the closed bow that I have the panel removal was comparatively easy.
Old 03-19-2013, 02:06 AM
wheelerd's Avatar
wheelerd wheelerd is offline
Boat: 2005 X2
I redid my TriStar carpet although not as heavy weight as yours. As I recall I used soapy water or maybe KY on the edges of the panel. They slid in quite easily. (OK, OK, no jokes needed! )
