Old 03-11-2013, 04:49 PM
drschemel's Avatar
Boat: 1990 Tristar 190 closed bow
looks like someone side-swiped a dock. easy to do! A good repair would require getting behind the place and putting some extra fiberglass down to reinforce it then grinding the cracks out and filling with gel. An OK repair would be just putting the glass on the inside. A bad repair would be covering it up with a wrap! I looks like is is not in a structural part of the boat and wouldn't lilely cause any safety issues. Still probably a $1500-$3000 repair and should be taken care of before any deal to buy the boat. You just never know if they are going to find a stringer cracked when they access the hull.
Old 03-11-2013, 05:46 PM
MASTIQUE's Avatar
MASTIQUE MASTIQUE is offline
Boat: Past: 1986 MC 19 Skier; Nautique, 230, 2009, PCM 343; Current: X-45 ZFTP5, ILMOR 6.0L
http://austin.craigslist.org/bod/3597906948.html
MASTIQUE's Avatar
Maybe this is the one your looking at
Old 03-11-2013, 05:51 PM
gts-20's Avatar
gts-20 gts-20 is offline
Boat: 2008 Prostar 214 w/ mini tower mcx
I've seen that boat listed for sale for a long time. I would keep looking....find a better boat. Don't be afraid of the MCX. Its a great motor.
Old 03-11-2013, 06:07 PM
GoinBoatin's Avatar
GoinBoatin GoinBoatin is offline
Boat: 2006 x-45 8.1L
Yea that's the one I'm looking at. I've heard people talking about it being underpowered. We plan on doing a lot of wakesurfing.
Old 03-11-2013, 06:27 PM
bobx1 bobx1 is offline
Boat: SOLD 2007 X1
I wonder if there are any fiberglass stress cracks around the tower legs. If so then I would run away.
Old 03-11-2013, 06:44 PM
Skipper's Avatar
Skipper Skipper is offline
Boat: 1995 MC Prostar 190
When the gelcote is cracked then the fiberglass underneath is cracked. The previous repair was no good because the root problem, damaged fiberglass, was not corrected first. That area will have to be ground off to the fiberglass, the fiberglass repaired, and then gelcote applied.
1995 Prostar 190
Remember, we must share our waters and be respectful of other boaters. Rude people suck!
Old 03-11-2013, 07:19 PM
MASTIQUE's Avatar
http://www.boattrader.com/listing/20...ft-X-35-351646
here was the other one I saw, higher then I remembered....
Old 03-11-2013, 08:07 PM
GoinBoatin's Avatar
Would it being a saltwater series make it worse then if it wasn't? I would never be using it in saltwater. The other SS I've seen are usually cheaper too.
