Hmmm, so would it be a re-wire type deal?
#12
Probably not much of one. Most people bypass the lanyard switch and it's over.
'96 ProStar 205 SD LT-1 |
#13
Forgive me but I'm not much of an electrical genius... how would you bypass it? Isn't the purple wire the one that allows you to charge your batt?
#14
The purple wire I am speaking of goes from the ignition switch to the lanyard switch, back to the helm and then to the main plug on the back of the engine. If the current is broken on that wire, the ignition shuts down. The boat will crank, but the ignition is off and the gauges won't work either. The idea is to shut the boat down in the event of a driver ejection. If you go to the back of the lanyard switch (next to the throttle) and take the wires off and connect them, you have bypassed the switch.
#15
I really, really appreciate the help man. |
#16
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com SPECIAL PRICING CONTINUES Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. Spare tires too. |
#17
#18
Thanks a lot man, I've checked/replaced the switch. Seems it's the purple wire but as table rocker was saying locating exactly where its proving to be a pain in the balls.
#19
Thanks a lot man. I'll give it a whirl!! Really appreciate the help!
#20
Also, listen for the fuel pump when you turn the key on during the problem. You should hear the electric fuel pump run for a couple of seconds. If it doesn't, it is probably the lanyard not letting voltage get to the pump.
Search this site on "lanyard switch bypass" and you will find plenty of info.
| Tags |
| alternator, electrical problems, electrical wiring |
