  #61
Old 03-12-2013, 05:14 PM
What you got going?
Swingin' up thursday... makin' sales calls in twin cities thursday - staying in Wodbury.. then hang heading up to Rogers Friday thru saturday evening - then running back home saturday pm.
Old 05-12-2013, 05:10 PM
d2jp's Avatar
d2jp d2jp is offline
Reviving this thread from a couple of months ago as I started on '89 PS 190 today. What better Mother's Day present than getting the boat ready, right? The fiberglass covering the shaft log was easy to remove, and obvious water was entering between the aluminum log and the hull. My boat has the Powerslot and there isn't enough room to move the log/seals, etc forward and access the area in order to re-attach it properly and re-fiberglass.
So...it looks like I need to remove the coupling and will do the cutlass bearing while I'm doing.
The coupling nut looks like 1-1/4"? Guessing that as my 1-1/8" socket was too small. Pretty sure I can secure the coupling with a pipe or strap wrench. I've read the 'how to' on using a socket and getting some longer bolts to allow the coupling to free from the shaft. And, when reinstalling, how tight do you tighten that sucker?
I will post up some pictures later on.
I'm debating whether to reattach the shaft log by bedding it in a layer West Systems G-Flex epoxy or using 3M 5200. Once it's bedded in, I will cover the shaft log with G-Flex resin and glass mat. I've worked with epoxy and mat in the past on lots of boats, but first time for some of the other stuff. I don't have a lot of 'spare' time so I'm looking for some tips to keep me from having to re-do a step or three
So, bed it in G-Flex or 3M 5200? ......And I'm open to any suggestions and tips on removing the coupling and prop. Everything is soaking in PB Blaster right now.
Thanks in advance,
Jack
Jack
1992 ProSport 205
Smith Mountain Lake, VA
Old 05-12-2013, 05:26 PM
Boat: 1998 Maristar 200VRS
Well, 5200 takes a week or more to cure. If you're planning on skiing soon, I think I'd suggest epoxy. But, I'm not an expert.
Old 05-12-2013, 06:08 PM
d2jp's Avatar
Thanks Frank, I'm at least 3 weeks away from using the boat, so drying/curing time isn't an issue (yet). Looking at it closer, it looks like the aluminum shaft log on my boat was set down on a layer of Bondo. It's pinkish in color, hard - but you can chisel into it. I'm guessing that was put down to account for the slight V-shape of the hull and the flat surface of the aluminum log.
Bondo?
Jack
1992 ProSport 205
Old 04-13-2014, 05:40 PM
Razzys Wagon Razzys Wagon is offline
Boat: 1987 pro star 190
took mine out today and sure enough, I got the same leak now....got about 3-4 inches of water in about 10 minutes......not good.....looks like im starting a repair next week.....
Old 04-13-2014, 05:45 PM
good luck on repair... could be worse - post up pictures...
Old 04-13-2014, 05:49 PM
John 3:16-18
Old 04-13-2014, 07:10 PM
will do mike, cloaked- my shaft log is leaking where it is epoxied to the hull......
Old 04-13-2014, 07:51 PM
just ordered the epoxy....will have it Thursday or so. hope to have it apart and prepped when that arrives and just apply the epoxy and back together it will go.....with fiber glass on top of course....
Old 04-17-2014, 05:42 PM
i got stuff in.....it will be a few days before I get started though....
