Old 03-08-2013, 06:19 PM
tph's Avatar
tph tph is offline
Originally Posted by reftech View Post
Tph I agree 100 percent! I kinda freaked out at first that's why I took it to the fiberglass guy but this job really hasn't been bad! I'm using epoxy on the entire job with high density filler added to bond the log to the hull.its going really well!
Great job! And now you can sleep at night knowing it was done right.
Old 03-08-2013, 06:54 PM
reftech reftech is offline
Boat: 1987 mastercraft prostar 190
That's right! That's a big reason that I went and got the boat back because I knew if I did it myself I would do it the right way and would feel good about it. Thanks for the support!!
Old 03-08-2013, 07:19 PM
now slip over to the friday night drink thread and share congrats on a job well done!
Old 03-09-2013, 07:53 AM
Haha mike I definitely celebrated with a beer or twelve last night!! Gotta do the fiberglass matting today and hope to make a few slalom runs tomorrow afternoon it's suppose to be 70 degrees here!
Old 03-09-2013, 01:17 PM
Two layers of fiberglass mat applied. Should I do a third??
Old 03-09-2013, 01:37 PM
How did you get the log off? did you just cut around the edge and pry it off?
Old 03-09-2013, 01:55 PM
Mike after I ground the fiberglass mat around the log off it lifted right out so im guessing the original adhesive had deteriorated and that's why it was leaking water.
Old 03-09-2013, 02:04 PM
Well that was easy - yikes... I guess you don't need much to hold it in place... thanks... good info for future reference...
Old 03-09-2013, 03:48 PM
Yea I don't know what kind of adhesive was there originally but I epoxied it back in with a thick bead using high density filler in the epoxy resin mixture. It should give no more problems.
Old 03-09-2013, 06:31 PM
Third layer of fiberglass mat done. Will install new packing material tomorrow and take it to the lake. Really a straight forward simple job. I will pick up some bilge paint this week and cover repaired area.
