Old 03-06-2013, 01:21 PM
reftech reftech is offline
Boat: 1987 mastercraft prostar 190
Drive shaft log leaking help!!
Hi guys my 87 prostar 190 has a bad leak where the drive shaft log penetrates the hull. Any ideas on how to repair? Has anyone run in to this problem before?
Old 03-06-2013, 05:24 PM
FrankSchwab FrankSchwab is online now
Boat: 1998 Maristar 200VRS
Well, the normal path for water into the boat there is through the packing around the driveshaft, inside the big-ole brass nut just below and out of your picture. That's a normal maintenance item and easily adjusted. Are you sure the water isn't coming in there?
If it's actually coming through some kind of break in the fiberglass, I can't help you. You'll probably have to get someone knowledgeable to decide if the crack is a structural problem, or something simple that a patch of fiberglass and a spot of resin will take care of.
So, I guess, the first problem is finding exactly where the water is coming in.
Old 03-06-2013, 05:33 PM
MCOCD@13 out of 10
+1 on Frank's comment.... a video or more specifics where the water is coming in. If it's a bad shaft log it can be replaced. It could be as simple as needing new shaft packing... where is the water intrusion originating? - some water is normal... a few drips per every 10 seconds ok. or you can get a dripless packing.
Old 03-06-2013, 06:24 PM
The water is coming in through the fiberglass. I'm very familiar with replacing shaft packing but unfortunately that's not the issue on this one. The boat is at creative fiberglass now (a local shop) and will be ready next week. I'm not a fiberglass guy and figured I would leave it to a skilled hand because we are looking to start skiing in the next couple weeks. I will post pics of the repair when I get it back. Thanks guys!
Old 03-06-2013, 07:49 PM
tph's Avatar
tph tph is offline
Leak
Looks identical to my '89. In my case the solution was to remove all the glass on top of the shaft log, reattach the log to the hull with epoxy and glass over the whole assembly. Took 4 -6 hours and it's been working great for several years.
Old 03-07-2013, 07:16 AM
Tph that's exactly what has to be done on mine! Thanks for the input man!
Old 03-07-2013, 08:47 AM
MCOCD@13 out of 10
re-glass job - not too bad - 4-6 hours? What does that kind of repair cost? Looking forward to after pics.
Old 03-07-2013, 12:27 PM
What's up mike!? Haven't heard from ya in a while.. The repair is gonna hit me for 250.00 and that was a big deciding factor for me because I'm currently out of epoxy resin and mat so I would've had a good bit in materials if I bought the west system stuff because they are very proud of it u know. So he says I should have the boat back next week and I will post the repair pics.kinda wish he would send me some progress pics.
Old 03-07-2013, 12:30 PM
That doesn't sound too bad.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
SPECIAL PRICING CONTINUES
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 03-07-2013, 01:20 PM
Not at all. And I've seen his work. There is a guy on a local lake we ski on that hit a log and ripped his rudder off leaving a huge hole in his hull. This guy repaired it and did a really nice job for 600.00 so I'm optimistic about it.
