  #31
Old 05-06-2013, 11:44 AM
rspiecha's Avatar
rspiecha rspiecha is offline
Boat: 1994 Prostar 205/2005 Maristar 210 VRS - MCX
Who did you email at Mastercraft for the paint codes for the trailer??? I'm thinking about painting my UFP tongue replacement.
Thanks
Rob
2005 MariStar 210VRS - MCX - ACME #845
1994 Prostar 205 TBI 350 (SOLD)
War Eagle
Old 05-06-2013, 11:23 PM
thamax thamax is offline
Boat: None
Waymires never updated there website cali trailer works has a listing not specific to mastercraft but looks like a match for both tongue sizes. looks like $275 for all the parts
http://caltrailerworks.com/online/home.php?cat=156
Old 05-07-2013, 12:00 AM
2010Prostar197's Avatar
2010Prostar197 2010Prostar197 is offline
Boat: 2010 Prostar 197
Waymires has a picture and the cost is around 169 plus the cost of the inner member.
I'm sure you can probably get them from your MC dealer also.
It's a specific retrofit for Reliable swing tongues that bit the dust.
The one you show is a weld on version unlike the UFP retrofit which is unbolt the bolt and pull the pin simple.
Both I'm sure are functional. I wasn't going to cut and weld a trailer that looks brand new.
The Waymires guys are very informative and helpful
Old 05-12-2013, 11:00 PM
magnum's Avatar
magnum magnum is offline
Boat: Mastercraft X-Star 2006 L18
Got my new actuator from Waymire installed on the trailer today after painting it. Got all 4 wheels bleed so back in business with Brakes on trailer now . Hopefully no more brake problems for a long time
Mastercraft 06 X-Star 8.1L
Old 05-14-2013, 02:05 PM
jadmars jadmars is offline
Boat: MasterCraft X2 2007
Where to get a new actuator?
I contact Waymires today and was told 450.00 shipped. Seems a little on the expensive side. 07 X2 Trailer same problems.
Old 05-14-2013, 02:50 PM
mzimme's Avatar
mzimme mzimme is offline
Boat: 2006 20' Vdrive
I'm going through this right now with an 06 boatmate trailer. I see all the parts online, and know I need the outer shell and inner actuator, but what else besides that? Piston? Resevoir? Shock? Spring? Anything else I need for the internals?
This seems pretty complete, and a good price too. However, I think it's a weld on.
http://www.amazon.com/Hydraulic-Sing...words=ufp+a-60
-Mike
Old 05-14-2013, 03:15 PM
214skier's Avatar
214skier 214skier is offline
Boat: Current: 2014 PROSTAR 214v ~ Former: 2010 X14v | 1997 PS190 w/ LT1
Trailer issues
Guys--I apologize for the thread jack; however, my 2010 tandem trailer is behaving badly. Two symptoms: 1) trailer is jumping / surging as I slow to a stop and 2) intermittently locking up as I back to the ramp.
Is this possibly an issue with a faulty actuator as described in this thread?
Old 05-14-2013, 04:38 PM
Jadmars....
My outer member (4 inch tall) was 169 and the inner member (4 wheel disc) was 219
Can't remember the shipping but I'm 110 miles from Indy
Is yours 4 or 5 inches tall?? Not sure if it makes a difference price wise
I believe you can get the UFP inner member for slightly less if you look elsewhere but then you have to consider shipping if you are a long way away
Old 05-14-2013, 08:41 PM
Ramerman,
Good question...
I assume you have the dreaded Reliable assembly?
What I have found with mine is it leaks, and the brake system diminishes...
A broken dampening spring can cause what you describe when stopping along with oil/grease on the rotors/drums
Backing up should yield nothing unless you have a flexible brake line kinked in the swing away tongue. It gets kinked and the pressure never releases making the wheels appear to jump/slide
How do the rotors/drums look? Like they have been to hot???
Old 05-16-2013, 12:09 PM
mzimme's Avatar
Does this come with the master cylinder, spring, and all other internal components of the inner sleeve? Do you re-use the parts from the old actuator in the new one? I need help understanding this as I need to purchase something along these lines. My entire brake system is shot on an 06 boatmate trailer.
-Mike
