Old 03-04-2013, 07:16 AM
Theclarks1111's Avatar
Theclarks1111 Theclarks1111 is offline
Boat: 2007 X2
Alarm In Acc Mode
This has done this for as long as I can remember and it is finally driving me crazy enough to ask for some help. I have an 07 X2 and I can not turn the key from RUN straight over to ACC without getting an alarm. If I wait for about 30 seconds after I turn the boat off, I can then move the key to ACC without an alarm. Very annoying! Any thoughts would be appreciated!
Old 03-10-2013, 06:45 PM
Boat: 2007 X2
No one has had this happen to them....!!
Old 03-10-2013, 07:42 PM
ttu's Avatar
ttu ttu is offline
sorry no help here. i have the same boat same year and never had a issue. maybe someone will chime in on this.
Old 04-22-2013, 05:40 PM
neil.anderson63's Avatar
Boat: 2007 X2
Same for me as ttu - Alarm sounds from where? Under the dash, engine compartment? I found a small horn under my dash and have ZERO ideas what it is for.
Old 04-22-2013, 06:42 PM
bobx1 bobx1 is offline
Boat: Was 2007 X1 - now looking
Sounds like a possible low voltage alarm?
Also, search "low voltage alarm". You may not think that is the case if you charge the battery and continue to get the alarm but it takes a fully charged battery AND I believe it takes some on/off/on cycles to clear the alarm (if the alarm is in fact from low voltage). Mine ended up clearing the alarm because I unhooked the battery, charged, then re-connected.
Good luck and hope this helps!
http://www.mastercraft.com/teamtalk/...=battery+alarm
