Thanks for the advice! will be making a rack soon! just need to get some ideas. gonna surf over to your site now.
2010 X15 Surf Tabs, 4 wet sounds pro 80's , heater, underwater lights and the mcx! |
#12
(backstory unknown) |
#13
@bsloop:
That is painful to even look at.
1991 ProStar / 351W with 1:1 Velvet Drive |
#14
You can look in Sodar's stereo install thread. He made some blocks and I think fiber glassed them to the hull to mount his amp boards on.
http://www.mastercraft.com/teamtalk/...ad.php?t=28992
Gone, surfing. |
#15
from my beer pong table experience, I have found that a laminated piece of wood that has plies oriented in different directions (like cabinet facing) will also help reduce warping. so coating that in resin would add a double layer of protection.
#16
#17
I wouldn't recommend that.
Won't all those screws create drag when underway?
www.earmarkmarine.com |
#18
In order to attach mounting blocks to the hull...
Cut away sections of carpet where blocks will go. Sand the interior gelcoat/glass. Clean up with a solvent. M
#19
Cut away sections of carpet where blocks will go. Sand the interior gelcoat/glass. Clean up with a solvent. Mineral spirits, paint thinner, easy on the acetone. Fiberglass resin coat birch blocks. Double .75" thick if you want. Drill in a number of .125" deep X .25" diameter holes on the bottom of the blocks for a better mechanical bond against the hull (before coating). Glue in place with Dynaglass, KittyHair (filler with glass strands) or a 3M fiberglass body panel adhesive. Apply pressure until cured (24 hrs). Now the hull flexes, so, make sure that the panel rests on the sole, via shallow polymer pads. This will have most of the weight supported by the sole making the hull connection for mostly lateral support. Again, do not screw anything to the sole within a few inches of the hull. As the hull/dead rise changes, the sole can get very thin at it's perimeter. David
#20
A couple questions...
What grit sand paper do you recommend to sand the fiberglass? Would "3M/1 gal. Bondo-Hair long strand fiberglass reinforced filler" from Autozone be a sufficient product to use to attach the board to the fiberglass? Thanks! Quote:
