Old 02-28-2013, 12:34 AM
MC25's Avatar
MC25 MC25 is offline
Boat: 2016 X30, 85 S&S
Amp Walls/ racks! Lets see them!
Trying to get ideas to clean up my amps as I just installed a third. If there is a thread on this please enlighten me! searched but no luck. Pics to come so i can start it off!
-Aric
LONE STAR MASTERBASH 2018
Details released eventually
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
1985 S&S- For Sale
Old 02-28-2013, 12:55 AM
epnault's Avatar
epnault epnault is offline
Boat: 2016 ProStar 6.2L
I made thick sheet metal, stainless, frames for my amps and sub that are tucked under my observer seat. I will take some pics when I am at the cabin this weekend.
Old 02-28-2013, 05:43 AM
Boat: No Boat
Tim
Old 02-28-2013, 07:38 AM
Theclarks1111's Avatar
Theclarks1111 Theclarks1111 is offline
Boat: 2007 X2
What is the frame made out of?
Old 02-28-2013, 09:25 AM
EarmarkMarine's Avatar
Boat: TBD
Aric,
You can see a ton of examples in our installation gallery. I like the simplicity of an amp panel built from resin-coated 0.75" thick cabinet-grade birch clad in a marine-grade rubber-backed non-mildew carpet. Elevate the bottom of the panel 0.50" off the sole and it's virtually bulletproof. The birch and resin are available from any Home Depot. For cooling you can slightly elevate the amplifiers off the surface. This gap can also serve as a wire passageway if you want to route all cables behind the panel. There's also the easy servicibilty of building your wire raceways above the surface with the power accessing from one side and the signal path accessing from the other. Either route is more production level than custom but very fiunctional.
David
Earmark Marine
www.earmarkmarine.com
Old 02-28-2013, 10:48 AM
bsloop bsloop is offline
Boat: 91' MC 240sc
Rack I had saved as an example of what I might like to do with my 4 that are currently pulling on my bulkheads. I thought I had pics of mine but cant seem to find them......
Old 02-28-2013, 10:58 AM
Boat: No Boat
Just 3/4" pressure treated plywood.
Tim
Old 02-28-2013, 11:38 AM
Brian B's Avatar
Brian B Brian B is offline
Boat: Brand new 01 X10
Old 02-28-2013, 01:39 PM
MC25's Avatar
Those are all clean! Im deathly afraid to drill into the fiberglass under the observers area, so this is the best option for me.
-Aric
1985 S&S- For Sale
Old 02-28-2013, 02:07 PM
Boat: TBD
And you should be afraid...very afraid.
Never, ever drill into the fiberglass unless you have confirmed that factory inserted a mounting pad in a particular location.
If it's an appropriate location, then use a 'stop' on your drill bit to control the depth when drilling a pilot hole. And the pilot hole should be the EXACT depth as the screw penetration depth.
Never drill into the sole within 3 to 4 inches of the hull.
David
Earmark Marine
