Old 02-27-2013, 10:24 AM
WC205's Avatar
WC205 WC205 is offline
Boat: 2004 Prostar205v
Bilge Pump Replacement
Need to replace the center bilge pump on my 2004 Prostar 205V. It will run but won't actually pump any water. Below is what I have now. Wondering if the one in the link is the correct replacement. Also hoping that I can just unplug the old and then clip the wiring right into the new.
http://www.overtons.com/modperl/prod...view&from=grid
Old 02-27-2013, 11:02 AM
Lumbergh's Avatar
Lumbergh Lumbergh is offline
Boat: 1991 ProStar 190
Amazon sells a variety of bilge pumps.
Usually the best prices as well.
Worst case, clip wires and install new pump.
Easy project, sometimes tight quarters but nothing to worry about.
Old 02-27-2013, 11:05 AM
Table Rocker's Avatar
Table Rocker Table Rocker is online now
If it will run, you might take it apart. There is an impeller in there that might be full of carpet fibers and sludge. If you break it, you haven't really lost anything.
'96 ProStar 205 SD LT-1
Old 02-27-2013, 11:24 AM
Here are some instructions:
Old 02-27-2013, 11:27 AM
rgardjr1's Avatar
rgardjr1 rgardjr1 is offline
When I replace mine a couple of years ago I was able to find and exact replacement on Ebay. The basket that the pump mounts to on the bottom of the boat may not be the same-pull yours out and see if you can tell compared to the picture on the Overton's page.
2006 Maristar 200 SS
Old 02-27-2013, 11:31 AM
WC205's Avatar
Awesome. I'll check it out before I buy anything. Thanks.
Old 02-27-2013, 11:40 AM
Glad to help, let us know how it goes.
Old 02-27-2013, 02:07 PM
rgardjr1's Avatar
If you do end up needing one I saw this one on Ebay that was the older version:
http://www.ebay.com/itm/370765432870
Once you pull yours out to see if you can get it pumping you'll be able to tell if this one would be a direct replacement.
Old 04-18-2013, 05:57 PM
WC205's Avatar
You were right. Just full of filth muck in there. Cleaned it out and it pumped. You saved me some cash so THANKS!!
Old 04-18-2013, 05:58 PM
I'm glad it worked out. Thanks for the update.
