Old 02-24-2013, 04:54 PM
Lumbergh's Avatar
Lumbergh Lumbergh is offline
Boat: 1991 ProStar 190
Wheel Bearing Size
I'm going replace my wheel bearings, yet another winter project.
The victim: 1991 single axle Mastercraft factory trailer, no brakes.
After researching this, I have not located the bearing kit size. Would like to pre-order the 2 bearing kits online.
Any help here?
TIA!
Old 02-24-2013, 05:02 PM
got a caliper?
Old 02-25-2013, 08:18 AM
Legolamb Legolamb is offline
Boat: 1996 Prostar 190, LT1
Not sure if this will help, as my trailer is a '96 single axle Mastercraft but my bearings and seals are as follows:
Spindle size OD= 1 3/8" x 1 1/16"
Inner bearing L68149, inner race L68110 (koyo)
Outer bearing L44649R, outer race L44610 (koyo)
(UFP kit 07007U0)
Seal size is 1.688" x 2.328" x 1/2" wide. Should use a double lip seal, UFP 07027U.
Old 05-29-2014, 07:03 PM
brighac's Avatar
brighac brighac is offline
Boat: 89 tristar 190
Heres what I used on mine. It's a tandem axle with breaks for an 89 tristar 190 made by sweetwater metal products. Instead of the L68110 I used the L68111 because there was play with the L468110. But that could have been from the bearing explosion From when I talked with Dwayne at SWP they used the same on breaks and no breaks. Actually I have one axle with and one without.
-Austin
1989 tristar 190
Old 05-30-2014, 03:23 PM
homer12's Avatar
homer12 homer12 is offline
Boat: MC Tristar 190 OB, 1989
brighac, does your trailer "porpoise" with one axle having brakes? I have same year, guessing same trailer as you - '89 tristar 190 riding on tandem axles.
Old 05-30-2014, 05:21 PM
brighac's Avatar
Nope. Barely notice it back there. Is the boat sitting on the trailer right? I have noticed it seems to be a 2 person job to get the boat on the trailer right. I have found the sweet spot to back it in where the water line is between the two tires on the fender. Even then it's challenging to get it to stay up all the way. Easy way to check is to make sure the bunks are flush at the back of the boat. The trailer has a pivot between the two springs
-Austin
1989 tristar 190
Old 05-30-2014, 05:33 PM
I can deliver a pair of pre-greased hubs with the following specs for $95
Or a pair of bearing kits for $42.50
Bolt Pattern: 5 on 4 1/2"
Load Capacity: 1875 lbs.
Front Bearing ID: 1 1/16" (L44649)
Rear Bearing ID: 1 3/8" (L68149)
Grease Seal ID: 1.719"
Spindle Style: Straight
Pre-Greased: Yes
Dust Cap: Standard
Old 05-30-2014, 07:40 PM
Lumbergh's Avatar
With the pre greased option, can one just unbolt the old and bolt in the new?
Thanks!
Old 05-30-2014, 07:59 PM
Thanks!
And while you're there, put a set of Bearing Buddy (and bras) on hubs.
A new hub assembly is my preference.
John 3:16-18
Old 05-30-2014, 08:37 PM
Lumbergh's Avatar
I have BB and BB bras on right now.
Just looking to spend more money on my money pit.
