Old 02-24-2013, 10:06 AM
SunCoast 83's Avatar
SunCoast 83 SunCoast 83 is offline
Boat: 2009 Tournament Team 197
Gas Overflow on PS 197
I am having an issue with gas spilling (very small amounts) from the fuel overflow valve near the transom (port side)
The boat sits in my garage and I worry about the fumes.
I had brimmed the tank to the top and added Stabil a couple months back. When I noticed it I took it to the lake and ran it for about 30 min.
Well a week later it started again. Did I not burn enough fuel?
Anyone else had this?
Thanks
2009 ProStar 197 Tournament Team
No. #46 of #100
Old 02-24-2013, 10:12 AM
Hecker's Avatar
Hecker Hecker is offline
Boat: 2012 X25
You probably just have a little fuel traped in the vent line. I don't know how easy it is to get at on your 197 but I would disconnect the vent line at the tank and blow it out.
Old 02-24-2013, 10:23 AM
Does that happen from overfilling the tank?
No. #46 of #100
Old 02-24-2013, 10:40 AM
Hecker's Avatar
Boat: 2012 X25
Yes. The fuel is cool when stored underground and expands when it warms up. If your tank is right full and not sitting just right it will push fuel instead of air out your vent.
Old 02-24-2013, 01:07 PM
millpondkid millpondkid is offline
Boat: 84 mastercraft stars and stripes 351 with powerslot
I had the same issue last summer when I topped off the tank. As the boat sat in my shop for a cpl days the heat inside expanded the fuel and I had a puddle under the overflow vent. I siphoned some out and used oil dry to soak the puddle.
Old 02-24-2013, 02:50 PM
If I get out and run some of the fuel out then problem solved correct?
Thanks for all the help on this.
I just don't want gas running down the side of the boat....not the best stuff for the gel coat
No. #46 of #100
Old 02-24-2013, 02:55 PM
ricford's Avatar
ricford ricford is offline
Boat: 1996 Prostar190
Like Hecker said, you may still have some fuel trapped in the vent line. 30 minutes of running should have burned enough.
Old 02-24-2013, 06:05 PM
dihrdskir's Avatar
dihrdskir dihrdskir is offline
Boat: PS 197
Don't sweat it, that's what the vent is for. I never top off the tank and just fill it to the first click at the bowser. It's far better that the fuel is on the outside of the hull rather than in the bilge. Drain some more if it persists and wash off the gel.
Old 02-24-2013, 10:51 PM
Thanks I just worry about the fumes. Due to the gas runoff I will have to replace a decal on the back part of the boat. I will have my dealership order a new one.
Just pissed about it. And it's my fault.
No. #46 of #100
Old 02-25-2013, 11:39 AM
tph's Avatar
tph tph is offline
fuel/air separator
Or there is something like this....
http://www.jamestowndistributors.com...eyword=product
