Can a loose timing chain rattle
All summer I have been thinking this rattle clunking sound is from my transmission but everything in the tranny is mint. So if now I'm looking into the engine end of things, would the timing chain be first to check when searching for a clunking rattle at low rpm and hot.
It is possible for the timing chain to have so much slop that it hits the cover. Usually if it is excessively loose you will have other problems such as hard starting from little or no cranking vacuum and lack of performance. Should be able to find the source of the sound using a long screwdriver or, better yet, a mechanics stethoscope.
Note: if your wife has a stethoscope from her occupation she will not see the crossover use as reasonable. ![]()
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com SPECIAL PRICING CONTINUES Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. Spare tires too. |
Here's what you need: http://www.skidim.com/prodinfo.asp?number=R140001 |
