Old 02-21-2013, 03:59 PM
1988prostar190 1988prostar190 is offline
Boat: Mastercraft Prostar 190 Indmar 351 Ford Windsor
Can a loose timing chain rattle
All summer I have been thinking this rattle clunking sound is from my transmission but everything in the tranny is mint. So if now I'm looking into the engine end of things, would the timing chain be first to check when searching for a clunking rattle at low rpm and hot.
Old 02-21-2013, 05:23 PM
jhall0711's Avatar
jhall0711 jhall0711 is offline
Boat: None
Did you check your dampener plate? That is the common rattling sound in these trannys.
Old 02-21-2013, 05:28 PM
It is possible for the timing chain to have so much slop that it hits the cover. Usually if it is excessively loose you will have other problems such as hard starting from little or no cranking vacuum and lack of performance. Should be able to find the source of the sound using a long screwdriver or, better yet, a mechanics stethoscope.
Note: if your wife has a stethoscope from her occupation she will not see the crossover use as reasonable.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
SPECIAL PRICING CONTINUES
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 02-21-2013, 06:25 PM
tockit's Avatar
tockit tockit is offline
Boat: 1989 190 Tristar
Most definitely your damper plate! I just went through this last year with my 1989.
Here's what you need: http://www.skidim.com/prodinfo.asp?number=R140001
