Old 02-27-2013, 08:26 AM
Patrick Hardy's Avatar
Patrick Hardy Patrick Hardy is offline
Boat: 1996 Prostar 190 W/ LT-1 & Powerslot
Here is my set up on my PS190. It is a 12" free air kicker sub connect to an approx. 2'x2' piece of carpeted marine plywood under the drivers dash. It has been in this location for seventeen years. IMHO it sounds great and functions well for the limited space on a older 190. As for all of the perfect harmonic applications, I could not tell you, but for listening to music between ski sets it works great.
Old 06-26-2013, 06:24 PM
KelBCx9's Avatar
KelBCx9 KelBCx9 is offline
Boat: Mastercraft X9 2003
Thanks for the idea, I did the same style for my X9. I did 2 Kicker CWRT 10"s. I used 3/4 MDF and then primed and Raptor Box lined outside. Used their tintable stuff.
Old 06-26-2013, 06:43 PM
Rossterman's Avatar
Boat: 2001 prostar 205V
If the same underdash as a 205v you can read my sub box construction and install which has dimensions and pictures on our forum.
Old 06-26-2013, 07:43 PM
BriEOD's Avatar
BriEOD BriEOD is offline
12" Kicker sub in a sealed box sprayed with truck bed liner.
Old 06-27-2013, 05:53 AM
Rossterman's Avatar
I have a 2001 205v and built a sealed box under dash for a 10" sub. Pics, dimensions, etc are in my post on this site in case you want to follow my plans. Works amazingly better than the free air sub i replaced and should be adirect fit for yours.
Old 06-27-2013, 08:43 AM
http://www.mastercraft.com/teamtalk/...t=47493&page=4
Yea you did yours always identically to mine. I built mine and then attached it to the factory sub location. Sounds much much better now
Old 06-28-2013, 04:12 PM
Granite_33's Avatar
Granite_33 Granite_33 is offline
Boat: X-10
Since its up underneath the Dash, I bought a pre-assembled box from the local car stereo joint. Put a Dayton Audio RSS265HF-4 10" Reference HF Sub (home audio sub) in it. Hooked it up, needles to say it hammers.
The sub is meant for home audio, but realistically, the sub is under the driver side dash, the boat is under a canopy, covered when not used, and rarely sees moisture.
I would not recommend doing this if the sub is going to be exposed. But being under cover like that, I saw no issues.
Unbelievable how much better it sounds vs the old Clarion open air sub.
16' X-10
04' X-9.
91' Maristar 210.
Old 06-28-2013, 05:05 PM
Yellow X9's Avatar
Yellow X9 Yellow X9 is offline
Boat: Mastercraft X-9 05
Being a home sub- is it 8ohm ? if so, I might suggest a 4ohm sub- will produce better bass allowing you to get to a 2ohm load on the amp your running it on
