  #41
Old 03-02-2013, 12:08 AM
Kyle's Avatar
Kyle Kyle is offline
Boat: 93 Prostar 190
The wires on mine are not run up inside the pipe. They are stuffed in a plastic stick on wire loom on the side. I can take a pic of that.
It's basically the wire loom sticks that you can get at Home Depot and use 2 sided tape to stick it to a wall or something. It has a groove in it where you can stuff the wire in from the side.
I don't know what they are called but you know what I'm talking about.
Rollin' Gangsta Style
Old 03-02-2013, 06:33 AM
clrussell's Avatar
Boat: 1990 mastercraft p190
Yea I'll try to get a picture of the rack, it's not adjustable unless I cut it off and weld it back on. Mine isn't a fly high pole or anything like that its one I made. I don't really plan to use a Bimini. My pole is around 6 feet to the top, so I have to duck around boards which isn't that big of deal. Let me see if I can find a better pic
Tapatalk
1990 prostar 190, 351, powerslot 1.5:1, tinted windows
Old 03-02-2013, 10:55 AM
Kyle's Avatar
Tapatalk
Ok just an idea here.
Weld on a bracket to the rack that will allow you to build it all together. Or cut what you have and integrate it into an enclosure. Weld it back together and then build the enclosure around the rack.
Maybe weld on some nuts to the rack where you can make it removable from the enclosure.
Send a rack pic and more thinking out loud would be nice.
Old 03-02-2013, 11:00 AM
clrussell's Avatar
That's the pole, sorry for the crappy pic, I can take a more detailed one if needed. I can make brackets to mount enclosure on it, was planning to weld a mount on so I could remove speakers if I ever needed to. Think out loud as much as you want, I need all the ideas I can find
Tapatalk
Old 03-02-2013, 11:04 AM
Kyle's Avatar
Does the rack hold 2 or 4 boards. How does the top rack hold 2 boards w/out them flying off. Do you have straps?
Old 03-02-2013, 11:13 AM
Kyle's Avatar
I have an idea but it would mean not using your racks.
Anyone could make one then since the rack is discontinued.
Take a piece of pipe that will fit the OD of the skylon or whatever brand pole.
Cut the pipe to a legnth of 4-6" long.
Then cut the pipe long ways in half.
Weld on a flat piece that would be 6-8" long and runs horizontal on the vertical pipe. Weld on 2 2" tabs to each edge of the vertical pipe.
This way you have a clamping pipe to fit on the skylon pole.
Get some cutting board material and I'll trace my rack then cut the rack out.
Build an enclosure exactly like mine.
Basically you would need to build a clamp system and then cut out plastic racks. It would be real easy to do.
Old 03-02-2013, 11:18 AM
clrussell's Avatar
It holds 2-4 boards in the rack, the side that's yellow is where I put my boards, they go in between the yellow rubber pieces, to put 2 boards in it one has o have boots up and one with boots down, I usually just have a knee board on the other side and it fits perfect in the gap, I'll stick a couple boards in it when I get home and take a picture. I have straps to hold the boards in too
Tapatalk
Old 03-02-2013, 05:29 PM
Rockman's Avatar
Rockman Rockman is offline
Boat: 1995 Barefoot 200 Yamaha ProV 200, 1994 ProStar 190 LT1 1:1
Attachment 90541
Tapatalk
AAAAAAAAAAAAHHHHHHHHHHHHHHH the bloody wall in the rental property! It's back!!!
Just givin' ya a hard time!
Old 03-02-2013, 06:02 PM
clrussell's Avatar
Lol! Yep it's back!!
Tapatalk
Old 03-07-2013, 02:27 PM
Kyle's Avatar
Bump bump bump
Clrussell
Have you come up with any more ideas?
Let's keep this Kustom thread going.
Do you mind drilling through your pipe. Is your pipe aluminum? Do you know how to weld to the pipe material.
Trying to think how make it all tie together
