Old 02-16-2013, 06:52 PM
SWGA Boater's Avatar
Boat: 1991 Prostar 190
S&S Escort Engine/Block Problem
Some of you may know that I am rebuilding a 77 S&S. Today I was breaking down the engine for painting. I found one freeze plug missing. I have never heard the engine run, but supposedly, the engine is less than two years old. Not sure what to do? Would you replace the plug, or just go ahead and break the engine down and have the block checked. Boat came from NC, so freezing could be a possibility. I pulled one valve cover and the rockers and pushrods are clean, so it is possible the engine is "new". Thoughts on how to approach this issue? Next step? I did not want to have to breakdown the engine if possible.
Thanks.
Old 02-16-2013, 07:11 PM
JohnnyB's Avatar
JohnnyB JohnnyB is offline
Boat: 2004 Prostar 190
Put it back in and do a pressure test of the coolant loop and then a compression test.
Sent from my Motorola RAZR MAXX using Tapatalk 2
2004 Prostar 197, ACME 843
Old 02-16-2013, 07:12 PM
MCOCD@13 out of 10
good question....
Old 02-16-2013, 07:23 PM
JohnnyB's Avatar
Crap...just read the post again...how far is it broken down for painting??
Old 02-16-2013, 09:25 PM
Motor is out of boat. Have engine mounts off, alternator, brackets, raw water pump, fuel pump, etc. pretty much everything except waterpump, manifolds and carb. Was thinking of reinstalling freeze plug and then do a coolant pressure test as suggested (if possible). I did not see a crack or anything around the plug hole.
Old 02-17-2013, 09:50 AM
JohnnyB's Avatar
I think that would tell you a lot and give you some peace of mind
Old 02-17-2013, 10:13 AM
Cloaked Cloaked is offline
Boat: MasterCraft
If you truly want a good nondestructive test for cracks (hairline included) take the engine to an engine shop and get them to do a magnet particle test on the engine (typically on the heads and any suspect area from visual observation). Very easy to do, should be inexpensive, and is effective.
You can do the test yourself with the right equipment. Takes a kit (magnet prod and particle matter) and a 110v outlet.
