Old 03-05-2013, 11:18 AM
rodltg2 rodltg2 is offline
Boat: 2017 PS
Send a message via AIM to rodltg2
Back seat for 1996 ps 190
Now I have found a 96 for sale but back seat is missing. Anyone know if its possible to find one and if so how much ?
Old 03-05-2013, 11:50 AM
most likely have to build one unless stealbay has one
Old 03-05-2013, 12:16 PM
Table Rocker's Avatar
The entire back seat is missing, or just the bottom?
'96 ProStar 205 SD LT-1
Old 03-05-2013, 12:27 PM
carlsonwa's Avatar
Boat: 2006 Prostar 197 TT
I have one from my 99' Sportstar, its basically a giant cushion. I believe the prostar rear seats were much thinner and set up on the small shelves on each side in the rear..
Old 03-06-2013, 08:16 AM
BrianM's Avatar
BrianM BrianM is offline
Boat: 1988 Prostar 190
The Prostar seats are nothing like the one above. It is a flat cushion that slides in the slots on each side. Would be super simple to make. Just cut the shape out of plywood, foam and upholster. The seat back is three pieces that attach to the boat and are not easily removable. I bet those are still there. I definitely wouldn't let a missing rear seat cushion keep you from buying an otherwise clean boat.
Old 03-06-2013, 08:42 AM
^what brian said. I would make the ply/epoxy it yourself. I found a local person to do my rear seat for like 120. Just make sure they use SS staples Mine was just reg ply sandwiched. Was about the weight of a ballast babe at the end of one season and flimsier than this country's leadership.
Old 03-06-2013, 11:41 AM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
I rebuilt the seat bottom on my 96. Used 2 pieces of 1/2" marine plywood in the strong direction glued and nailed together. That was closest to the orig seat base thickness and it held up well with no center support although I did add a center support after the first year to help it live longer.
I had the old one as a pattern but could fit a cardboard pattern pretty easy then get an upholstery shop to foam and cover it.
'06 X2 MCX
Old 03-07-2013, 02:52 PM
dmminfla's Avatar
dmminfla dmminfla is offline
Boat: 1997 PS 205 5.7L 275 HP TBI
I think you need one like this. I had it made for my 97 PS205 for $200.00
Old 03-07-2013, 02:55 PM
carlsonwa's Avatar
What material did you use for the base of that seat? Any support in the middle?
Old 03-07-2013, 03:03 PM
Theres a few ways to skin that cat. You can use 1/2 sandwiched ply like dm was saying. Reg ply and expoxy it.....etc, honeycomb aluminum. Simplest and cheapest is a split between marine ply and expoxied reg ply. MY PS had a stock metal brace on the bottom that is like a 1"x1" metal bar
