  #81
Old 05-02-2013, 08:15 PM
dmaxstore's Avatar
dmaxstore dmaxstore is offline
Boat: 2003 X80
Originally Posted by clrussell View Post
Still stock turbo? Or decide to go ahead and add something else?
Tapatalk
Using stock turbo, it will be perfect for the power levels we are going for.
Old 05-02-2013, 08:34 PM
clrussell's Avatar
Awesome, can't wait to see final product.. Look great!
I'll send you a pm about trans kits in a bit
Tapatalk
Old 05-14-2013, 12:29 AM
dmaxstore's Avatar
Boat: 2003 X80
Motor came back out for some minor adjustments. Its back in now and getting ready for harness.
Custom adapter made to connect fresh water impeller to our ATI harmonic damper. This adapter came out sweet, thanks Airpoint
Old 06-06-2013, 08:05 PM
dmaxstore's Avatar
Boat: 2003 X80
Estimated temps this weekend are in the triple digits. Our mission is to have this boat burning diesel by next weekend and making waves in Lake Tahoe over the 4th of July.
Final electrical, IC plumbing and exhaust system under fabrication.
We will need some Props for testing, (Anyone?)
Old 06-06-2013, 08:18 PM
Traxx822's Avatar
Traxx822 Traxx822 is offline
um um um um um .... oh my god.
1 Corinthians Chapter 13 - 11
Old 06-07-2013, 05:58 PM
thamax thamax is offline
Boat: None
can you tell us about you water to air intercooler looks big and bolted together so it can be cleaned? will u run straight from the raw water pump to the intercooler then the motor?
Old 06-07-2013, 06:14 PM
dmaxstore's Avatar
Boat: 2003 X80
Penninsular diesel supplied the intercooler it is serviceable. It is the same one they have been running on their 6.5 diesels for years. It will get raw lake water through it. This boat will use a closed cooling system with a Penninsular diesel heat exchanger and oil cooler. Raw water will run through the oil cooler then the heat exchanger next the intercooler followed by the manifolds and up pipes exiting out the exhaust down pipe and through the OE exhaust ports.
Old 06-07-2013, 06:57 PM
Jerseydave's Avatar
TT Hero
Great work so far. That D-max would be such a great engine in an X-star!
I can picture it now......a lifted 2500 Suburban with a D-max pulling a D-max powered X-star!
Can you say "dream rig!"
I was njskier on here.
Old 06-07-2013, 07:23 PM
dmaxstore's Avatar
Boat: 2003 X80
She will look good behind our tow rig.
Old 06-08-2013, 12:56 PM
dmaxstore's Avatar
Boat: 2003 X80
We are waiting for some more mandrel bends to show up Monday so we can finish up the inter cooler piping,cooling, and exhaust systems. We test fit the motor cover late yesterday and had to loose about 2 inches off of each rear ice chest to clear the air charger and heat exchanger. The fit is very good and this re power looks like it came off the showroom floor.
Our ECM is on its way back from the master of all Duramax tuning (Rob Coddens) we should be uploading some running video by next weekend.
