  #131
Old 07-10-2013, 12:25 AM
thamax thamax is offline
Boat: None
what prop is on right now size and pitch? maybe somebody knows what they ran with the Yanmar diesels back some years ago when MC had a short run of them or the current TDI diesels! was the ever a X-80 with twin Yanmars? i've seen twin LY6 but nothing bigger
Old 07-10-2013, 11:43 AM
dmaxstore's Avatar
dmaxstore dmaxstore is offline
Boat: 2003 X80
I would love to know what the details on that prop are also. The current prop that was on the 8.1 and still on now is an OJ 14.75 x 17.5. A friend of mine is loaning us a 14x20 with a 180 cup for testing this weekend.
Old 07-10-2013, 12:45 PM
Boat: None
That is a big change in size and pitch there is a yellow 05 x-star on eBay with a yanmar diesel no prop or spec pics maybe contact the seller for some insight. I think u have the power to spin a pretty large prop but picking the right pitch is tricky and cup size! Is it making 500ft pounds of troque but 1/3 slower
Old 07-10-2013, 01:05 PM
dmaxstore's Avatar
Boat: 2003 X80
Currently making 360hp and 700ftlb's wich is pretty much stock power, we will probably bump that a bit also. Yes the loaner prop is a big jump, trial and error time.
Old 07-10-2013, 01:15 PM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
The Yanmar has considerably less torque than the Dmax so not a good comparison.
I've seen 19.5 pitch props on the Lsa x45.
Jumping from 17.5 to 20 pitch should give you a few more mph at least.
Not sure how limited in dia the x80 is but I think much over 20" pitch on a 14" ish prop and you won't have enough surface area to take full advantage of the added pitch.
Very interesting awesome project. Keep up the good work.
'06 X2 MCX
Old 07-10-2013, 03:50 PM
76S&S's Avatar
76S&S 76S&S is offline
Boat: 2002 X Star
I don't know for certain, but I would guess that the Yanmar doesn't turn nearly the rpm's of the D'max. So, I'm not sure that is a good comparison.
2002 X Star
Sold - 76 S&S
Old 07-10-2013, 04:52 PM
Boat: None
I understand they are totally different setups. rpms is everything on boats! all the gasers spin at 5-5200 rpms while the redline on this dmax is somewhere in the high 3000-4000k so alot of difference that is my point there. yanmar 6LP is rated up to 3800 rpms! they still build them check there website out yanmarmarine.com
Old 07-10-2013, 05:39 PM
dmaxstore's Avatar
Boat: 2003 X80
The LMM Duramax has a Redline of 4700 rpm. We have limited the Redline through tuning to 3300. We increased the out put speed of the prop with the new V-drive ratio. More adjustment can be made with tuning and prop selection.
Old 07-10-2013, 07:55 PM
Boat: None
Are you hitting 3300 rpms right now? where will you set the redline after tuning?
Old 07-10-2013, 08:13 PM
jgraham37128
I would call Eric at OJ props I bet he will know exactly what you need.
