'06 X45 w/MCX 350 hp - is that enough HP?
New to the forum and MC.
I am looking at a used '06 X45 with 116 hours and wanted to see if anyone had an opinion on the MCX 350hp engine. I have some reservations about this MCX not having enough power for the large and heavy X45. We are not an expert wake boarding family, however we love to be on the water and tube/wake board/knee board. Our family boat will be stored on a lift and use in a fresh water lake with little chop. Thank you in advance for your comments. |
General consensus is no, it's really not ideal for power. I'd say not enough for sure if you were at any sort of altitude or running heavy ballast for wakeboarding.
For general duty, surfing, boarding yes it will work. You can prop it down quite a bit and get a decent hole shot at the expense of cruising rpms and top speed, or vice versa. If the price is right, reflecting the smaller engine, I'd go for it. 5.7 is bulletproof and the 45 is a darn nice boat. By comparison an 06 X45 (MS245 with X pkg) just sold on here, 8.1L low hrs, was listed at 50k. Price dependent on condition, hours and options.
Thrall, thanks for the reply. Here are the specs on the MC X45, seems like a good deal, but I'm new and unsure.....
06' X45, 120 hours, 1 owner, all service records up to date, boat in very good condition, some color fading on transom (due to sun fade). (I have yet to have an independent tech inspect the boat). Asking $47,500. While I would prefer the 8.1L, getting a good price and low hours could be a valid trade off. |
Honestly, you can't ever have enough hp according to most but for the average boater or boarder I wouldn't even think to upgrade to an 8.1 your fuel burn will cost you double to go boating IMO
07 X45 with 8.1 sold on ebay for $50k with less than 200hrs
IMO most fuel burn is done while getting boat to plane and the 8.1 will do it easier with little effort opposed to the MCX requiring more throttle and more time to get on plane 310 RTP and 350 MCX just not enough hp for any MC more than 22' or 7000 lbs |
Asking price if it's pretty loaded is only a few thousand more than a comparable X2 and a few thousand less than a comparable X15, so sounds like a decent deal. I only have experience with a X45 with the SC6.2 LSA engine and it moved out! Best bet, take it for a lap, load it down, see if it's enough engine or not. Note, prop selection will make a HUGE difference. Find out what's on the boat and if possible get a higher or lower pitch prop to swap and compare to. I can't imagine it is that bad or MC would not have even put it in the boat to begin with. The X45 is arguably MC's best layout/do it all boat (exc skiing of course). Best looking too! And 120hrs is brand new, essentially.
I own a 2005 X-45 with the MCX 350 engine and an OJ 14.75 x 15.5 prop. We use it mainly for wakeboarding, hydrofoiling, and surfing. When running full factory ballast and a boat full (10-12 passengers), I've never felt like I'm lacking power in the hole shot. The engine does start to work a little too hard for my liking over 30 mph, but I don't really have any need for the higher speeds. Fuel economy seems really good with the MCX which I would imagine would suffer quite a bit with a larger engine. I've owned the boat for about 4 years and have had zero problems with the motor...it's solid.
We have a hard time pushing a loaded Star with the MCX. I can't imagine pushing a loaded up 45 with it. I vote no if you plan in loading it up with people,ballast, and more ballast. if you plan on surfing a ton and loading it up to surf or if you are an advanced rider I would not go with the MCX in the 45
However if you plan on using the boat as more of a recreational do everything boat,not really a core wakeboat or surf boat all the time and throwing tons of extra ballast in the MCX will do fine. That price and description are pretty good, but keep in mind if and when you do want to sell the MCX will also limit it's buyers. I will also argue about fuel consumption. Running a smaller engine at its higher rpm limits vs a larger engine at lower rpm's will yield pretty close to the same results at wake speed similar to what Snork mentioned. Once you get to around 30mph tho I can see the MCX doing a bit better while both boats are not loaded up all day long at cruising speeds.
2000 X-Star, 3000lbs ballast, LTR 330, Acme 1235 14.5X14.25prop. |
Please all empty your ballast when you are not riding!!!!
Your local owners of 19' direct drives thank you and are sick of having to start their boats to turn the bows into your wakes. |
#10
I wouldn't get an MCX in a 45. You'll be running near full throttle most of the time, burning just as much fuel as an 8.1 and wearing out that engine sooner. For probably $5K more you could have the bigger engine and really use that boat to its full potential.
I was njskier on here. |
