Old 10-04-2012, 12:47 AM
XStar08's Avatar
XStar08 XStar08 is offline
Boat: MasterCraft XStar, 08, LY6; MasterCraft ProStar 190, 91, Ford Mustang;
New 5 blade Prop
http://www.wakeprops.com/
Did anyone tried that one yet?
Old 10-04-2012, 12:58 PM
CantRepeat's Avatar
Boat: Boat
I've not used one but when I ask Eric about them he made it very clear that it was designed for very heavy loads, IE ballast and would reduce the top end quite a bit.
Tim
Gone, surfing.
Old 10-04-2012, 01:45 PM
501s's Avatar
501s 501s is offline
Boat: 2013 X-30, 6.0L, 2500lbs of Ballast, 500lbs of Lead.
Hmmm, I think I want one. I need a spare anyways.
2013 X-30, 6.0L with 2500lbs of ballast and 500 lbs of lead.
Old 10-04-2012, 11:45 PM
TN X-45's Avatar
TN X-45 TN X-45 is online now
Boat: Mastercraft X-45 2008 MCX
I'm still getting 40+ in OK water and great low end pull on an X45 with an MCX. OJ prop....Use it mostly for surfing.
Sent from my SCH-I535 using Tapatalk 2
2008 X-45 Canadian Blue Metal Flake/Silver Metal Flake, MCX, OJ 5 Blade
Old 10-04-2012, 11:57 PM
TheWoons TheWoons is offline
Boat: 2012 X-25
I have one and so does Mike. It didn't lower the top end at all.
2012 X-25
Old 10-05-2012, 08:09 AM
XStar08's Avatar
So what's better/different with the 5 blade TheWoons?
Old 10-05-2012, 11:22 AM
Boat: 2012 X-25
Everything. Idling, getting on plane, low end power with all the weight, maintains speed better in chop. Didn't change out top end either.
2012 X-25
Old 10-05-2012, 11:49 AM
CantRepeat's Avatar
Boat: Boat
When you say it didn't change out the top end are you saying completely unweighted the boat still gets 45+ ??
All I can tell you is what Eric told me and that was the top end would drop and I would not be happy with it. He did offer to let me test both the 5 blade and a 4 bladed he recommended to me. I'd be doing that the beginning of next year.
Tim
Gone, surfing.
Old 10-05-2012, 11:57 AM
Boat: 2012 X-25
There isn't an X25 on the planet that will go 45mph+ on a stock prop with a 5.7L. I've had two new X-Stars as well that both topped out at 38-39mph with no added weight (both 5.7's as well). With the 5 blade I still get to upper 30's close to 40 and that's the same as all three of my MC's. Someone on here did a Prop test and his results were the same as my findings and his top speeds were the same as my boats too.
2012 X-25
Old 10-05-2012, 12:40 PM
501s's Avatar
I contacted wakeprops about this prop for my X-30 and this was their reply:
Thank you for contacting us, Congrats on the new x30! The five blade is going to be less aggressive on the low end than what you are currently running. If you are looking to get on plane faster the Acme 2037 will defiantly get the job done http://www.wakeprops.com/acme-2307-propeller.html This going to be the best option for a weighted down boat and save you money in gas at surf and wake speeds.
