1984 Pro Star Resto..(maybe)
So I picked up this 84 PS 190 over the weekend. It was advertized as a 82 but was an 84'
I had a ton of questions about this vintage but I read the history thread posted by C36 and all the resto threads posted hear and got most thing covered. I thought MC went to all composite in 85' but according to C36 it was 83' Not sure how far I want to go with this project just yet. Seems to be a good candidate for a resto, how deep I go is to be determined. I do have a few questions, some pics attached: 1. Is there a way to check to see if the foam under the floor is soaked? 2. Is the floor fiberglass all the way up to the bow? 3. Is this the original location for the fuse block? 4. Are these the original decals? Any input or comments are welcome, Thanks!
1996 ProStar 190 Still slummin' behind PP Chippin' away @ the BLUE LOOP |
The floor and stinger system is bonded all the way around to the dies of the boat. It would be odd (in my opinion) to have water under the floor. If you wanted to check you would have to cut holes in the fiberglass floor. 2. Is the floor fiberglass all the way up to the bow? Yes. The main contruction of the boat will contain no wood. The only wood in the boat will be the seat bases and side pads. 3. Is this the original location for the fuse block? I dont think so. My fuses on my 89 are located up under the dash, not in the battery box. I could be wrong on this one as I have not seen too many of these boats up close or investiated that closely. Someone will chime in on this one. 4. Are these the original decals? No. This would have originally had stars on it. The graphics that are on it are more similar to the 87-90/91-94 decals. |
This is a 19' Skier, not a Prostar. I have heard water can get into the foam through the swim platform bracket mounts in the back as the lag bolts loosen. Check for water in the foam by removing selected motor mount bracket bolts. You can access foam from there. These will probably need to be tightened anyway. If the hull is not cracked, the engine sound, and the running gear not damaged, it should be a nice restore.
Congrats on finding a great project. This is going to be a great thread to watch. When I got my boat, it also had the stars removed and newer Mastercraft lettering on the side in attempt to make it look newer.
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com SPECIAL PRICING CONTINUES Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. Spare tires too. Last edited by thatsmrmastercraft; 02-06-2013 at 09:11 PM. |
Not fair - nice project...
... can't wait for engine pics....![]() ![]() ![]()
It even came with the star keychain!
#7
Looks like a nice project, more pics please!
Jim@BAWS can hook you up with the proper decals when you restore. The red boat in the pic has the proper graphics (Dogpaw's boat from Lake Anna VA)
I was njskier on here. |
#8
Nice find Mike. Interestingly somewhere in the past week here I read that wood stringers were sporatically used into 1984 which contradicts everything I've read in the past 10 years. I forget who posted it but is seemed credible when I read it and there is really now way to know for sure
'97 Prostar 190 - LT-1 Prior boats - 2009 X14, 2008 X14, 2005 197, 1988 Tristar 190, 1989 Prostar. |
#9
No wood. Looked back at the engine picks in the listing. Motor mounts are a give away. If you're on Facebook check out The MasterCraft Project. Lots of knowledgeable people re: Stars and Stripes there. Mikeg205 turned me on to it. There are a couple amazing projects in the works.
Decals and fuses are definitely not original.
I spent most of my money on booze, broads and boats. The rest I wasted. - Elmore Leonard |
